How To Open A Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-07-2014, 10:27 PM   #1
How to Open a Door?
Our back exterior door has a problem with the doorknob/lock.
The know will turn, but it does not engage the lock, and the door, of course, won't open.
We took of the know & tried playing around with the innards of the lock, but nada.
It's been like this for a while. Now, we're getting a new dishwasher, and it will have to get in through that door.
So (yay!) we have serious motivation to stop our procrastination.
Please, I need some good ideas.
If you need a pic, let me know.
Thanks in advance!
Locked In in NY
CheBella is offline   Reply With Quote
Old 06-08-2014, 06:01 AM   #2
Rewards Points: 13,994
Remove the whole knob and use a flat screw driver inside the hole to slide the latch over to release it.
The Following 3 Users Say Thank You to joecaption For This Useful Post:
oh'mike (06-08-2014), rossfingal (06-08-2014), Windows on Wash (06-08-2014)
Old 06-08-2014, 06:57 AM   #3
DIY staff
Rewards Points: 7,174
It sounds like the catch mechanism is worn out---time for a new one---
Old 06-08-2014, 08:47 AM   #4
Rewards Points: 2,400
Remove the pins from the hinges, pull it out from the hinge side. Then replace the opening mechanism.
ED
de-nagorg is online now   Reply With Quote
Old 06-08-2014, 09:25 AM   #5
Rewards Points: 236
i had a shlage that broke. even doing that^ wouldn't reliece(sp?) the bolt. there is a plastic piece in there that broke.
Fix'n it is offline   Reply With Quote
Old 06-08-2014, 09:34 AM   #6
Rob
Robpo's Avatar
Rewards Points: 826
release
Robpo is offline   Reply With Quote
The Following User Says Thank You to Robpo For This Useful Post:
Fix'n it (06-08-2014)
Old 06-08-2014, 08:39 PM   #7
Rewards Points: 236
Originally Posted by Robpo View Post
release
ya know, i used to spell very well. getting old sucks, but i guess its better than dying young.....
Old 06-08-2014, 09:19 PM   #8
They make a tool called spellcheck.
As well as a practice known as proofread.
Actually I have a dictionary within reach as I keyboard. Just in case I make an errer.
ED
Old 06-17-2014, 09:53 AM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
ED
I thought I made an errer once, but I was rong.
Old 06-17-2014, 10:38 AM   #10
Rewards Points: 736
The old trick about using a credit card actually works surprisingly well on a number of knobs. Don't use one you would want to break, but it's stupid easy to pop open a door that way.
TheBobmanNH is offline   Reply With Quote
Tags
door , lock , lockset
Garage door stuck, will not open JerryOC General DIY Discussions 15 08-26-2010 02:58 PM
Want to use a pulley /counter weight to open metal hatch door to cellar MACrowley Building & Construction 4 02-22-2010 05:41 PM
Adjusting Garage Door torsion springs INGunGuy Building & Construction 4 10-12-2009 07:22 AM
Keeping Door Propped Open dgreco3917 Carpentry 6 09-29-2009 09:19 PM
Stop a door from drifting open? Sliding Man Carpentry 17 11-16-2008 03:18 PM
