How Long For Window Glaze To Harden? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 06:19 PM   #1
Rewards Points: 682
How long for window glaze to harden?
I've read that one should wait 7 days before painting new window glaze. Does this mean that it takes 7 days before the glaze hardens?
thanks
darsunt is offline   Reply With Quote
Old 08-16-2011, 06:17 AM   #2
No, it means the surface is dry enough to paint. And drying time depends on weather conditions. It can vary from a few days to weeks. If you can touch it with your finger and it does not still move, you can usually paint over it.
Old 08-16-2011, 07:18 AM   #3
Learning by Doing
Leah Frances's Avatar
I waited a month before....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-16-2011, 06:52 PM   #4
Household Handyman
Rewards Points: 1,408
All of the above are correct. My granddad taught me how to properly glaze a window back in the mid-'60's, my Dad was pretty good at this also. "Just Bill" is correct in that after you do the glazing, the time it takes to dry will depend on the temperature and humidity the glazing is exposed to. The "finger test" is what most of us use, push very slightly with the tip of a finger and if the glazing does indeed move or there is a slight indentation, more drying is needed. The glazing compound contains some oils and when you roll it between your palms, you did do this didn't you?, it will pick up oils from your hands. These must dry for primer and paint to adhere properly.
How Long Do We Have? Docfletcher Off Topic 19 05-01-2010 11:02 AM
The long, dark road of renovation. Curb Feeler Introductions 1 02-03-2009 01:47 PM
How long a run to septic tank? GregWCIL Plumbing 8 06-28-2008 03:04 PM
How long should A/C take to cool house? AllGoNoShow HVAC 2 06-17-2007 07:01 PM
Long range HVAC planning. dalesd HVAC 2 02-23-2006 12:37 PM
