-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   How to install door that is not pre-hung and has custom jamb? (http://www.diychatroom.com/f104/how-install-door-not-pre-hung-has-custom-jamb-181521/)
amakarevic 06-08-2013 09:35 PM
I have an antique restored interior door with a transom for which I have to make my own jamb due to the height of the side jambs (big boxes sell only 80" door jambs). Should I
A) assemble the jamb and hang the door on it outside the rough opening before fitting it in (basically pre-hang it myself) or
B) assemble the pieces of jamb inside the rough opening?
I am inclined to think A because how else do I know how much shimming I will need. However, one problem I see with that is how to assemble 1x planks of the jamb at right angles around the door and set the hinges in correct spots. It seems like I would need a firm frame to support the composition.
oh'mike 06-09-2013 07:38 AM
You have a door and matching transom? If that is correct, I suggest you build the jambs and mortice in the hinges before installing the jab set.
All that fine work would be simpler for me to do in the shop---
Also easier to adjust the jambs while installing, than to trim the door to fit an already installed set of jambs.
