#1 |
How to fix a broken frame corner of a slide window
Part of a window frame at a lower corner is broken. The window is a up-down slide type. The material of the frame is probable PVC. The window is 8-year old. How to fix? By clue?
Thanks a lot for any tips! Last edited by George II; 05-07-2011 at 12:31 PM. Reason: rewording |
#2 |
Can you post a picture of the damage?
You can repair a certain amount of damage, but after a point you might need to replace the frame. If this is a replacement window, it's a much easier job then a new construction unit. Given that the company is still in business. Ron |
| Display Modes | |
| Condensation on fiberglass window frame | creamaster | General Discussion | 11 | 01-05-2012 08:42 PM |
| how to frame a deck around a bay window? | tpcolson | Building & Construction | 11 | 12-17-2010 06:01 PM |
| How to frame around basement window near sump | casnj | Building & Construction | 4 | 11-27-2010 05:59 PM |
| How to 'finish' outside of replacement window? | KatieAK | Building & Construction | 9 | 04-02-2010 07:37 AM |
| Problem with window and everything around it | malfunction | Building & Construction | 3 | 05-26-2009 06:11 PM |
