Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 05-31-2011, 12:42 PM   #1
How do you remove these window handles?
They don't go underneath the frame, the kind of "Plug into" the frame. I just can't seem to get them off after unscrewing the two screws.
Breakthecycle2 is offline   Reply With Quote
Old 05-31-2011, 12:50 PM   #2
Framing Contractor
If you rotate it halfway, there is a small screw in the handle
sixeightten is offline   Reply With Quote
Old 05-31-2011, 12:52 PM   #3
Sorry, I meant to include that. I got the screw and the handle off, but for some reason, it won't pull off.
Old 05-31-2011, 12:53 PM   #4
Framing Contractor
It may be jusTap it a few times with a hammer and see if that loosens it. Then just grab it and pull while wiggling it.
The Following User Says Thank You to sixeightten For This Useful Post:
Breakthecycle2 (05-31-2011)
Old 05-31-2011, 12:55 PM   #5
I will try that and report back. Thanks!
Old 05-31-2011, 03:43 PM   #6
Worked great! thanks!
How Can I remove the Grid line in Window? 5taehoon Windows and Doors 5 04-04-2011 09:59 PM
Stationery / Transom / Picture window ??? CoconutPete General Discussion 7 02-04-2011 10:36 AM
Removing a window for painting... JJDoherty General Discussion 6 08-31-2010 09:39 PM
Window Leak: Flashing or Window? lverma Building & Construction 16 08-31-2010 01:46 PM
Single Hung Window Removal for Drywall bparise Drywall & Plaster 2 12-12-2009 08:44 AM
