Thanks for your reply Mr. Whitehouse!
Originally Posted by AGWhitehouse
Is there a stop (removable piece) on the interior side of glass? If so, my approach would be to remove the stop, remove the glass, and then cut off the exterior "stop".
I'm not sure if there's a stop - I don't see a removable piece ... I just checked and I don't see how it's removable at all
. With the exception of the rot, the "stop" on the instide looks just like the one on the outside ...
From the looks of the picture the rotting is only happening in the stop location. Once cut off you should be left with a flat piece of wood. Go to the store and buy a piece of 1/2" minimum thickness wood (1/2" 1/4 round is ideal). cut to length and nail onto the window sill at the exterior with the vertical leg against where the glass will be. Re-install the glass and interior stop. Prime the exterior, paint the exterior and then fill the void between the new stop and the glass with caulk or glazing compound.
Do you think this can be done with the glass still in place?
p.s. Looks like you need to paint the balance of the frame before it all begins to rot.
Yeah, I was actually stripping the rest of the frame in preparation for the paint when I realized how bad the window, or transom or whatever, was.
Thanks again much for taking the time to reply!
V/r,
John
