How Do I Wrap A Rough Opening With Felt - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-22-2011, 03:44 PM   #1
how do i wrap a rough opening with felt
i will be installing a window with a flange and was hoping to get some info on the best way to do it using 30# felt paper.
i wasnt going to do Tyvek because ill only be doing about 25 feet long.
its basically new construction with osb as sheathing.
opening is about 41 x 48
thanks
rustic is offline   Reply With Quote
Old 09-22-2011, 08:05 PM   #2
Tom Struble's Avatar
Rewards Points: 2,002
window instructions will usually show you where the paper should be
Tom Struble is offline   Reply With Quote
Old 09-23-2011, 06:27 AM   #3
ummm....thanks?
Do i wrap the felt in the opening then install the window and then wrap the outside sheathing to butt against the sides of the window?
in a overlapping fashion of course.
Old 09-23-2011, 06:57 AM   #4
you can do it that way
exterior door rough opening jgcable Building & Construction 2 05-24-2011 08:08 AM
Odd sized existing rough opening in interior door. t_mott85 Remodeling 2 11-24-2010 12:56 PM
New rough opening to basement - spiral staircase benjamincall Building & Construction 8 07-16-2010 06:53 PM
Seal off area between rough opening and asphalt felt with spray foam? kooshball Building & Construction 5 12-14-2009 12:25 PM
Install Integrity windows over asphalt felt or other rough opening treatments? kooshball Building & Construction 6 12-06-2009 08:34 AM
