How Do I Fix A Double-hung Window Frame That's A Bit Loose? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-31-2015, 02:55 AM   #1
Rewards Points: 170
How do I fix a double-hung window frame that's a bit loose?
If you grab the window sill from the outside, the entire frame wiggles in and out about an inch. What's the best way to fix?
halliwellc is offline   Reply With Quote
Old 03-31-2015, 05:29 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,722
What type of material and construction type (i.e. new construction, insert, wood, vinyl, etc.).
Most likely solution is going to sink some screws through the jamb and into the framing of the home but I need a bit more information and ideally a few pictures.
Old 03-31-2015, 04:42 PM   #3
Rewards Points: 1,372
Also by wiggles do you mean that the bottom pulls out.....or the top.....or the whole thing? Ron
ront02769 is online now   Reply With Quote
Old 03-31-2015, 08:34 PM   #4
Rewards Points: 170
Standard pre-war double-hung wood frame. Bottom pulls out. I have made a ten second video to post.
Sinking screws through the sill to the wall framing seems like it wouldn't work well because there is a gap of several inches between them.
Old 03-31-2015, 08:39 PM   #5
Rewards Points: 3,130
Something would have to be very wrong to be able to move a window that far.
Sills are never screwed down.
No video needed, just need a simple picture.
Old 03-31-2015, 08:56 PM   #6
Rewards Points: 564
greatstuff in the counter balance weight wells? At the bottom so not to move the casing at the middle and jam up the sashes?
even a broken clock is right twice a day!
Yodaman is online now   Reply With Quote
Old 03-31-2015, 09:08 PM   #7
Countersink and scres in a 2 1/2" sheetrock screw through the side jamb into the jack studs, one on each side near the bottom, but DSL NOT crank them tight else you will pull the side jambs out of alignment. Ron
The Following User Says Thank You to ront02769 For This Useful Post:
Windows on Wash (04-01-2015)
Proper sealing of block to window frame. Trucon01 Windows and Doors 5 11-14-2012 02:36 PM
Changing Window Size TinaV Remodeling 3 11-06-2012 12:30 PM
basement window frame paint? s002wjh Painting 8 12-25-2011 01:06 PM
how to frame a deck around a bay window? tpcolson Building & Construction 11 12-17-2010 05:01 PM
Double Hung vs Single Hung CZSteve Remodeling 0 11-08-2010 07:29 AM
