-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   How do I adjust this old pocket door hardware? (http://www.diychatroom.com/f104/how-do-i-adjust-old-pocket-door-hardware-113709/)
ddavissn 08-11-2011 05:03 PM
3 Attachment(s)
Recently purchased 1903 Victorian. Double pocket doors, one side works great, the other drags on the floor so can't be opened and shut. I was wondering if anyone has ever seen this particular hardware. I'd like to know if turning that adjustment screw OUT would pull the door higher. Right now it is screwed all the way in. I know the obvious answer is to adjust it and see what happens, but the door is super heavy and difficult to work with, and the hardware is old and I don't want to play around with it unnecessarily. That hanging piece clips onto the top of the door (there's one in front, one in back) and holds it up. The further that clip is screwed out and away from the body of the piece, the further away the wheel will be from the edge of the door. Will that lift the door higher? I just don't get how this should work. Pix attached. Any advice is most appreciated.
BigJim 08-11-2011 06:14 PM
I may be wrong but it looks like the screw devise is sitting at an angle and the further it is screwed out the further down that end of the door would go. Is that correct? Is the screw devise part of the rollers?
ddavissn 08-12-2011 02:26 PM
No, the screw is not angled. It just goes "in & out" straight. That hanging clip snaps onto a piece on the top of the door (one in front, one in back). This is part of the roller...it's all one piece/mechanism. So it seems like the more you screw that clip out, the further away the roller will be from the edge of the door. It's not a simple "higher & lower" system, that's what's so confusing to me. When that clip is on, it lays flat on top of the door. I'm wondering if the further the screw is out (consequently the further the roller is from each edge), if that creates a pull that lifts the door up higher. I hope I'm making myself clear.
BigJim 08-12-2011 10:13 PM
That is what I was thinking but didn't know how to explain it. It is worth a try.
roundround 06-01-2015 09:02 AM
adjusting pocket door hardware
From what I have been able to discern with my 6 pocket doors of the exact same type, the unit lowers as you turn the screw cw and raises as you turn it ccw. If somehow, you have an extra left hand trolley and two bases that attach to the doors I could really use them to restore this 1920's house I am working on.
