How Do I Adjust A Commercial Door Closer? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-12-2011, 09:41 AM   #1
how do I adjust a commercial door closer?
I have one of those arm-elbow commercial door closers that acts like a shock absorber-closer. However it doesn't push the door all the way closed. There is a knob on it but no instructions. I'm cautious to touch it because I don't know what I'm doing. Any suggestions on how to get it to push the door all the way closed?
Thank you
h82diet is offline   Reply With Quote
Old 11-12-2011, 09:54 AM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 540
Thank you
Turn the knob and if the door closes faster you can either turn it more to make it faster or turn it the other way to make the door close slower. You won't need to turn it much, maybe an 1/8-1/4 turn.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
h82diet (11-12-2011)
Old 11-12-2011, 01:30 PM   #3
Ok... thank you. I'll experiment with it.
Old 11-12-2011, 05:39 PM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,250
Think of that screw as the dampner on a shock. You are just adjusting the valving and speed.
Small adjustments go a long way as jiju mentioned.
Old 11-13-2011, 10:00 AM   #5
Door closer adjustment
Only a very old door closer will have a knob for adjusting the closing speed. Your door closer may have adjustment screws on either end, the top or the bottom. Some closers will have a cover that must be removed to see the screws and there may be four screws (spring strength, backcheck, closing speed, latching speed). Don't adjust the door to slam. It may injure someone and it will shake the screws loose from the other door hardware.
Other reasons the door might not close:
1. door binds on threshold or frame
2. door closer worn-out or not installed correctly
3. hinges worn, rusted, bent
4. etc....
lockguy is offline   Reply With Quote
Old 11-13-2011, 04:59 PM   #6
The door is hitting the threshold and I'm going to try and sand it this week. The door is too heavy for me to take off myself (unless I can get my hubby to help). I took the plastic cover off and there is only one knob. There are no screws... I climbed up on a step stool and looked around.
I'll report back if I get it right!
Thanks!
Heating and AC size for old downtown commercial bldg Grizzlybare HVAC 9 02-24-2011 05:05 AM
Residential vs. Commercial Ballast. Gronon Electrical 3 02-21-2010 03:13 AM
Trafficmaster Allure Commercial Confetti Dark Grey Vinyl Flooring (24 Sq. Ft. Per Cas bennyjets Flooring 3 08-09-2009 10:50 PM
Commercial plumbing question Sasha2000 Plumbing 3 06-20-2009 03:12 AM
new commercial door in place of windows crecore Building & Construction 3 11-21-2007 05:29 PM
