How Deep To Set A Hinge Mortise On The Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-26-2014, 07:51 PM   #1
Rewards Points: 1,062
How deep to set a hinge mortise on the door
How deep should I set my hinge mortises with this retro hinges? Currently, I have it sticking out by 3/8" (distance between the pin and the edge of the door). I modeled that after a similar door in my house but I am unsure because that door also needs replacement and doesn't close fully. If I set the hinge all the way in, the pin head will touch the edge of the door, which does not leave much room for trim casing.
Essentially, what is the convention for how deep to set the hinge into the mortise?
Old 09-26-2014, 09:32 PM   #2
Rewards Points: 13,712
Fold the hinge 90 Deg. slide it tight against the face of the door and that's your depth.
It's sticking out way to far the way your showing it.
Old 09-26-2014, 09:53 PM   #3
That means all the way in. In that case, the pin ball will be in the way of the casing. I measured a brand new door and it's sticking out 3/8", the same this does
Old 09-26-2014, 10:06 PM   #4
Here is a factory mortise/hinge. Sticks out 3/8", just like I did mine.
Old 09-26-2014, 10:08 PM   #5
Then it's wrong.
Remove the casing, the casing was suppose to be set back from the edge of the door.
The casing on the hinge side sits tight up against the barrel of the hinge.
I've seen the casing get sanded around the hinges to make room for the pins but it looks like poop and is not the right way.
Done the way you have it the doors going to stick out to far from the jambs or stop moulding.
If the old door was mortised wrong before you may have to remove and reset the stop moulding. Just close and latch the door and install the moulding.
Old 09-26-2014, 10:17 PM   #6
Totaly different style hinge.
Are both doors even the same thickness?
Not even seeing any stop moulding on the jambs.
Are you trying to replace a hollow core door with ball catches on the top of the door with a solid door?
Old 09-26-2014, 10:21 PM   #7
No, they are two different doors. I modeled the retro door hinges after the new one's.
My concern at this point is, if I move the hinge 1/8-1/4" in, will the new screw holes be too close to the old ones, rendering them not as tight?
Old 09-27-2014, 01:16 AM   #8
If you use a self centering drill like you should have in the first place and use longer screws it should be fine.
Google "self centering drill bit"
Old 09-27-2014, 06:01 AM   #9
DIY staff
Rewards Points: 7,174
What you have is not bad--------1/4 to 3/8 is about right---
Note---the further out you have the hinge--the wider the swing--and the gap on the latch side must be a touch wider----or the door edge will hit the jamb on the latch side.
If the lock set holes are already drilled---be sure to make any door width adjustments on the hinge side----if you trim the lock side of the door--the latch set back will be to short.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
amakarevic (09-27-2014), BigJim (09-27-2014)
closet door options bubbler Building & Construction 2 01-09-2012 12:43 PM
Door Hinge Problem (Please Help!!) pseudoreal General DIY Discussions 7 10-15-2010 04:06 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 11:00 AM
