How Can I Remove The Grid Line In Window? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-04-2011, 06:55 PM   #1
How Can I remove the Grid line in Window?
I ordered 19 windows from Cascade last week with grid option.
(I now realized that Cascade is not that good quality)
and once we installed all windows the grid option look busy and bugging me.
Anyone have any opinions how to remove the grid line in window? without breaking glass?
Thanks..
5taehoon is offline   Reply With Quote
Old 04-04-2011, 06:57 PM   #2
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
Call Cascade................
tcleve4911 is offline   Reply With Quote
Old 04-04-2011, 07:29 PM   #3
kwikfishron's Avatar
Rewards Points: 774
Thanks..
No, there is no option other than new glass that will (with replacement labor) cost the as much as your original order.
Call them fast, first thing in the morning and cancel the order. Iíll give you a 50/50 chance.
Good luck.
kwikfishron is offline   Reply With Quote
Old 04-04-2011, 07:33 PM   #4
Thanks.. I wonder If I can refund it... =(
Old 04-04-2011, 07:40 PM   #5
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,374
The divided light is glued on with VHB (Very High Bond) tape. That ain't coming off.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 04-04-2011, 08:59 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Are they gbg (grids between glass) or sdl (simulated divided lite)? If Sdl, it's doable, even though you probably paid up the nose for them. If gbg, as mentioned, you'll need to replace either all of the ig's or the sashes. Not a cheap proposition.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
Grid power loss indicator ? Roy Rowlett Electrical 1 03-20-2010 09:53 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 08:39 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 04:49 AM
