A Hopper Or Transom Window - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-23-2012, 11:56 AM   #1
a hopper or transom window
My customer want 3 awning window above front door I have only limited space 54 wide by 12 inches help
seehales is offline   Reply With Quote
Old 03-23-2012, 12:31 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,676
Transom will be the way to go.
Otherwise, the operable frame and sash frame on an awning or hopper will make that 12" opening seem very small.
The Following User Says Thank You to Windows on Wash For This Useful Post:
seehales (03-23-2012)
Old 03-23-2012, 01:58 PM   #3
Thanks for the reply. Now is there a transom with 3 separate windows that open at would fit
Old 03-23-2012, 03:09 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Transom kind of insinuates that it is a non-operating picture window above another window or door. I dont think you'll find anybody that makes an awning @ 12" height. A hopper would probably be a possibilty, but that would look weird IMO, and as WoW said, it would reduce the amount of glass as well. I'd try to convince them to go with a fixed transom.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 03-26-2012, 08:14 AM   #5
Thanks for the replies. With limited space we are going with a pella 8ft door with small window glass that way she gets light and no peepers plus the door should match their new garage doors thanks again..
Old 03-26-2012, 05:43 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sounds like a good solution.
www.HomeSealed.com
Window AC in transom window delgriffith HVAC 18 08-13-2011 05:42 PM
Transom window repair options (with pictures) barlav Windows and Doors 4 06-14-2011 06:31 AM
Stationery / Transom / Picture window ??? CoconutPete General DIY Discussions 7 02-04-2011 09:36 AM
help need to know how to replace windows wrapped in drywall caide3 Carpentry 4 03-02-2010 12:41 PM
Problem with window and everything around it malfunction Building & Construction 3 05-26-2009 05:11 PM
