Homeowner Window Replacement & Interior Trim - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 10-28-2013, 06:18 PM   #1
I will be getting some windows replaced by a contractor here in a few weeks. The contractor said he is going to leave the existing window stools in place. After further thought, I would like to replace those ugly old stools with something with more detail. When replacing window stools, does this need to be done while the window is removed? Or can this be done after the windows have been replaced?
Some pics for reference...
I would like the 2 kitchen windows to look similar to this...
notoriusjt2 is offline   Reply With Quote
Old 10-28-2013, 06:37 PM   #2
747
registered
747's Avatar
Rewards Points: 534
Are those marble. The one in the kitchen if i remember the pic correctly. Has tile around it. Little tricky. So is the curve main bay. This would be done after window installed. The installer can definitely do it. Ask about options. It will add to the bill
747 is offline   Reply With Quote
Old 10-28-2013, 06:46 PM   #3
I would like to do it myself if at all possible (I am paying a lot of $$$ for the windows already). I will be getting the kitchen countertop replaced in the near future with a new backsplash, so that tile work can be repaired/replaced at that time.
How can the window stool be removed once the new window is in place? How is it fastened into the frame?
Old 10-28-2013, 09:11 PM   #4
Rewards Points: 13,748
Are you having replacement windows or new construction windows installed?
Are those old window aluminum?
Old 10-28-2013, 09:22 PM   #5
I assume they are replacement windows but I am not 100% sure. Does it make a difference when replacing the window stools?
yes the old windows are aluminum
Old 10-28-2013, 09:22 PM   #6
Those sills most likely are going to be construction adhesive attached.
Going to be hard to get out with that window in place.
I think I would remove the window, cut it in half with a ciruler saw and a diamond blade then knock it up from the inside to break the bond. May have to use a flat bar as a wedge then use a sawsall to cut through the glue.
To do that odd ball window I'd use one these to figure the angles to cut.
http://www.zorotools.com/g/00061622/...m_campaign=PLA
Just hold it in place and it shows the exact angle to cut both pieces.
DO you own a compound miter saw? Going to need one.
Old 10-29-2013, 05:10 AM   #7
So I should have the new stools ready to install when the window guys are here putting in the new windows (i.e. the windows are removed)?
Old 10-29-2013, 05:11 AM   #8
Does the window sit on top of the stool? Or does the stool butt into the bottom of the window? I need to know how deep to make the stool
Old 10-29-2013, 08:32 AM   #9
The window goes in and the stool butts up against it, The window does not sit on top of the stool.
The best way would be as the windows removed the stool is also removed. The stool and the rest of the trim could go on later.
http://www.bing.com/videos/search?q=...trim&FORM=VDRE
Old 10-29-2013, 02:50 PM   #10
Any special type of wood I should use?
Old 10-29-2013, 04:21 PM   #11
Nope, just pine trim will work. All those moulding profiles are available at an box store or lumber yard.
Consider using a wider stool. Lady like then so they have a place to sit there fofo stuff on or a Christmas candle.
I use 5" wide stools for this.
http://www.bing.com/images/search?q=...iles&FORM=IGRE
Old 10-29-2013, 07:12 PM   #12
does the new window stool have to be rabbeted? I assume that the current marble stool in place is not...
something like this
http://www.coronahardwood.com/ch/pro...ted+stool/view
Old 10-29-2013, 07:30 PM   #13
Not likely. That looks like a stool for an Anderson style window. Yours may be flat instead.
Old 03-13-2014, 06:25 AM   #14
Home Performance
HomeSealed's Avatar
Rewards Points: 712
That would be most excellent indeed!
To the OP: since this post is older, has this been done? How did it work out?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Window pane replacement help dgbehrends Remodeling 17 11-19-2011 10:06 PM
Old replacement window jsfoltz Windows and Doors 1 08-26-2011 07:27 PM
Window Replacement mark2741 Remodeling 5 07-21-2010 03:33 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 06:37 AM
How to install Replacement window in 2x4 frame? BFD8 Remodeling 18 01-07-2009 11:56 AM
