In Home Door Security - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-06-2011, 07:22 PM   #1
I was trying to find a better way to secure a door inside the home. Most in home locks can be opened by as simple as a credit card. Is there anything besides a deadbolt that can secure the door a little better as I do not want to have to drill into the home?
BryanVest is offline   Reply With Quote
Old 05-06-2011, 08:08 PM   #2
kwikfishron's Avatar
Rewards Points: 176
kwikfishron is online now   Reply With Quote
Old 05-06-2011, 10:05 PM   #3
Rewards Points: 5,336
Windows are a far greater issue then a door or two.
Precluding the use of a deadbolt because you don't want to" drill into the house" makes no sense.
Ron
Old 05-06-2011, 11:42 PM   #4
Remodeler
Rewards Points: 316
Properly installed entry locksets can't be opened with a credit card. That is the sole purpose of the small secondary plunger right behind the latch bolt. The larger latch bolt drops into the hole in the strike plate and the small secondary plunger does not, this locks the latch bolt in the extended position so that it can not be slipped with a credit card.
If you are trying to further secure an interior door, then you want to install an entry lockset. It must be installed so the strike plate is tight enough that the small plunger can NOT drop into the strike plate hole, if it is possible to shut the door hard enough to get the secondary plunger to drop into the strike hole then the latch bolt is no longer secure from being slipped open. Interior locksets do not have the secondary plunger.
Of course if someone really wants in that room an interior door is no match for a prybar or even a swift kick, a deadbolt won't help that situation much either though.
iamrfixit is offline   Reply With Quote
Old 05-12-2011, 10:44 PM   #5
I can tie my own shoes
algored2deth's Avatar
Take a look at door jamb armor
http://www.armorconcepts.com/Our-Sol...oor-Jamb-Armor
algored2deth is offline   Reply With Quote
Need advice on remodeling/renovating a prefab (mobile) home countrylifemom Remodeling 53 03-29-2015 09:15 PM
mobile home service to bond or not to bond rikmac Electrical 35 03-17-2010 04:47 PM
Owning a home (not a mobile home) on leased land? Badfish740 Off Topic 11 03-30-2008 10:34 AM
Home Addition destepan Building & Construction 6 12-05-2007 01:28 PM
A facelift for your home Grumpy Remodeling 0 07-07-2004 08:43 PM
