Holes Drilled In Windows??? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-19-2011, 01:49 PM   #1
Rewards Points: 91
Holes drilled in windows???
I just bought a house, and the previous owner had drilled 2 or 3 holes at the bottom of each window.
1) why did she do this? what purpose does it serve?
2) should I get them fixed? if so, how?
Photos are attached:
Holes drilled in windows???-img_1946.jpg   Holes drilled in windows???-img_1947.jpg
19mquinn79 is offline   Reply With Quote
Old 04-19-2011, 02:01 PM   #2
That looks like a storm window. When the screens are up and it rains it allows rain water to drain off the sill. Did they add a newer window on the outside and remove the original window? I see the window tracks but no window.
badsanta is offline   Reply With Quote
Old 04-19-2011, 02:24 PM   #3
Rewards Points: 91
thanks for the reply. looks like i have a lot to learn!!
the window was up, that's why you can't see it. thanks again.
Old 04-19-2011, 04:24 PM   #4
Home Performance
HomeSealed's Avatar
Rewards Points: 712
.......... he is right though, those are essentially "weep holes" to remove moisture.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 04-19-2011, 04:53 PM   #5
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
and allow bugs to come in. Look just about the right size to let wasps in.
I don't know what exactly I would use but I would likely screen off the holes so bugs don't come in them but still allow for drainage.
Proper way to flash exisiting windows when installing new fiber cement siding, plus.. deminimis Carpentry 8 09-23-2010 09:55 PM
Co. installing my impact windows measured all wrong. Now they want to "rig" them in. heydade General DIY Discussions 45 10-10-2009 03:44 PM
How to caulk windows the RIGHT WAY? fritzycat1 Painting 3 09-10-2007 06:32 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 10:23 AM
