Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 01-03-2013, 04:42 PM   #1
Hold Open Washer
Anybody know where to find a new hold-open washer for a storm door? I'm missing one, and I haven't had any luck finding any locally.
I guess if I had to, I could start hitting the flea markets/thrift stores and try to find a whole piston... or door.
Joeboo25 is offline   Reply With Quote
Old 01-03-2013, 05:34 PM   #2
JOATMON
ddawg16's Avatar
Hold Open Washer
As cheap as those closers are....just go buy a new one....by the time you spend the time and gas searching, you would pay for the new assembly.
The other option....find a large washer that will fit over the shaft....clamp it in a vice and beat the edge over a little bit...that should work.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 01-03-2013, 06:12 PM   #3
bbo
Hold Open Washer
kit with other stuff for less than 2$ at the orange box
http://www.homedepot.com/webapp/wcs/...938&ci_gpa=pla
bbo is offline   Reply With Quote
The Following 2 Users Say Thank You to bbo For This Useful Post:
ddawg16 (01-03-2013), Joeboo25 (01-03-2013)
Old 01-03-2013, 08:42 PM   #4
Hold Open Washer
Ha. Perfect. Now all I need to do is find more stuff to order so I don't have to pay $6.95 shipping.
Thanks.
Old 01-03-2013, 08:50 PM   #5
Hold Open Washer
Also from Amazon (affiliated sellers)...
http://www.amazon.com/Prime-line-Pro...ef=pd_sxp_f_pt
Switch Washer & Dryer Position? Anianna Appliances 5 12-12-2012 11:55 PM
Need help selecting a pressure washer!! (a little lengthy) RickDel Painting 16 04-04-2012 10:00 AM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 12:13 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 08:28 PM
To open up the kitchen or not timbo59 Building & Construction 15 04-30-2010 02:17 PM
