Hinges Are On The Outside. Burglars Welcome - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 11-20-2011, 07:55 PM   #1
Hinges are on the outside. Burglars welcome
Thanks in advance for your help.
In my new home construction, 2 doors to the outside (on the ground floor) have their hinges on the outside.
Drift punch the pins out, and you can make yourself welcome indoors.
The house about 6 to 8 weeks from completion.
Suggestions?
Thanks,
Garrett
GarrettP1 is offline   Reply With Quote
Old 11-20-2011, 08:21 PM   #2
Residential Designer
AndyGump's Avatar
Rewards Points: 660
Send a message via Skype™ to AndyGump
Hi Garrett, check to make sure the hinges are security type.
If so they will have a set screw on each one that you can access and see when you open the doors.
Andy.
AndyGump is offline   Reply With Quote
The Following User Says Thank You to AndyGump For This Useful Post:
Tom Struble (11-20-2011)
Old 11-20-2011, 09:59 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 854
As a default, if it is an exterior door, they should be.
Old 11-20-2011, 10:31 PM   #4
Registered User
Rewards Points: 4,902
For anyone with pre-security hinges, drill a small hole in the hinge-side door edge, 1/2" deep to accept the head and shank (3/8") showing of a 10d casing nail---nailed in the jamb opposite it. Drive the nail first, slowly close the door partially to mark location for hole. One at all hinges, pulling the pin won't remove the door, unless determined. Remember, locks are for honest people......
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
BigJim (11-21-2011)
Old 11-21-2011, 09:21 AM   #5
In a little over my head
Rewards Points: 706
I did the same thing as GBR. Except, I used 1/4' lag screws, left 1/2-3/4" protruding, then cut the heads off with a hacksaw. I used 2, midway between the hinges.
ratherbefishing is offline   Reply With Quote
Old 11-22-2011, 11:01 AM   #6
Mold!! Let's kill it!
Rewards Points: 2,012
Even better. Drill the lags into the hinge plates themselves. Then it's a metal to metal connection. Just be sure the lags reach back into the stud. Locks may be for honest people, but burglars are not fond of making all the noise and bother it takes to overcome good ones.
Or replace the hinges with non-removable pin type.
Old 11-22-2011, 04:01 PM   #7
Rewards Points: 706
I like Maintenance6's idea even better. When I posted, I'd forgotten that my lag bolts were matching up with holes in a metal door frame.
European Hinges for Curved Kitchen Cabinets thiftyspender Carpentry 2 04-20-2016 09:00 AM
Space for hinges on custom closet doors nrk411 Carpentry 3 07-11-2010 08:34 PM
Blum hinges from 15 years ago?? MI-Roger Carpentry 14 02-23-2010 01:44 PM
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 08:47 PM
Remove paint from hinges on cabinet debpie Painting 3 11-09-2009 01:09 AM
