Hinge Pin Help - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-04-2013, 12:04 PM   #1
Rewards Points: 175
Hinge Pin Help
I'm remodeling my bathroom, and removed the door. Unfortunately, one of the hinge pins rusted stuck, which caused me considerable problems until I turned to you guys (Stuck Hinge Pin).
Now, I'm putting things back together. I'm putting in new hinge pins. Is there any hinge pin (e.g., stainless steel) that's better than others for this damp/wet location?
Also, any lubricant you recommend that stands up better over time? Some possibilities:
o Wheel bearing grease
o White lithium grease
o Motor oil
o WD-40
o One of the PB Blaster products
o Liquid Wrench
o Silicon
Thanks for your help,
Richard
RichardZ is offline   Reply With Quote
Old 09-04-2013, 04:32 PM   #2
Rewards Points: 14,020
Just replace the whole hinge with a solid brass one and never have to do anything to it.
Old 09-04-2013, 06:11 PM   #3
Rewards Points: 175
joecaption, I like that idea! Unfortunately, I have a steel door frame, and one half of the hinge is welded to it. Thus, I can't swap it for a brass one. On the other hand, could I put in a brass hinge pin, and acheive the same result?
Richard
Old 09-04-2013, 06:20 PM   #4
Nope, going to set up electrolysis with dissimilar materials.
Need a steel pin.
Just use some WD 40 on it.
If it's rusting then the humidity is to high.
Stuck Hinge Pin RichardZ General DIY Discussions 13 08-21-2013 01:25 PM
How to create hinge mortise on bevelled hinge edge using a router & jig? Toronto Carpentry 20 07-29-2012 10:53 AM
door hinge into a plaster wall? dbpass Remodeling 1 05-03-2011 11:49 PM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
Re-Securing A Hinge In A Stripped Out Door Frame CGofMP Carpentry 9 05-05-2005 11:00 AM
