High Lift Garage Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-22-2013, 10:27 AM   #1
High lift garage door
my opening is only 7X8 . I need to install the 7x8 garage door which would need to curve and go into garage as close to ceiling as possible so that the distance between the bottom of the door in up position and the ceiling is no more then 15 inch. (including the hardware) . Is this a mater of radius? what other things I should be aware of? Thank you
veinrock is offline   Reply With Quote
Old 05-22-2013, 10:34 AM   #2
JOATMON
ddawg16's Avatar
Rewards Points: 852
Piece of cake....
But some advice...pay to have it installed. I 're-installed' my door after I rebuilt my garage. 2 guys knowing what they are doing will knock that out before you finish your second beer.
I'm the epitome of the DIY'r....but no more garage doors for me. Same with roofs...and stucco.....and digging holes....and hauling off concrete.....and washing the dog (that's the kids job)
ddawg16 is online now   Reply With Quote
Old 05-22-2013, 10:48 AM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Are you trying to get the garage door closer to the ceiling than normal?
Garage door framing stevekem Building & Construction 12 11-02-2012 08:53 AM
Door recommendations from basement to garage Tyrus3 Building & Construction 7 07-20-2012 09:12 AM
Lift master 1/3 hp garage door opener Kbrodsky General DIY Discussions 8 05-05-2010 03:42 PM
Convert garage door to high lift door? 65cobra Building & Construction 5 06-23-2009 09:38 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
