#1 |
Help: Replace bottom weather stripping on sliding patio door
is this an easy task to do? a little bit of air comes through and during the wetter months we continually get bugs rolly pollies coming through the gap in our sliding glass door. It looks like it's just the weather stripping that needs replacing on the bottom or some adjustment somewhere. any help or links tutorials is greatly appreciated.
#2 |
Usually, there's a bar at the top of the door that's removed so the door can be tipped in the room and lifted out of the opening. Sometims the door is dropped by adjusting screws at the bottom, so the door clears the upper lip. You will probably need 2 people to help with the door as it will be heavy.
You would need to know the doors manufacturer or have a sample of the weatherstripping profile to replace it. If you're lucky, it might be sold locally. Another option would be to apply a rubber piece at the bottom side of the door to close off the opening. You would fabricate it so an opening for the track was just wide enough for the metal.
Ron "They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." B. Franklin 1759 |
| Display Modes | |
| Pivoting Shower door replacement questions | inspectator | Kitchen & Bath Remodeling | 5 | 07-22-2011 10:00 PM |
| Pre-Hung doors - How to Hang | Willie T | How To Guides | 23 | 01-28-2011 10:24 AM |
| Replace door sill = Need new door? | NNJGUY | Carpentry | 23 | 09-01-2009 02:54 PM |
| installing patio sliding door on concrete pad | jwms | Building & Construction | 6 | 04-19-2009 01:46 PM |
| Sliding Glass Door Replace: Help | roztom | Building & Construction | 4 | 07-22-2008 09:07 AM |
