Did a search on the net to no avail. We purchased a house that has a couple of doors that have a old Schlage door lock set on them. I am able to remove the knobs but the actual latch assembly is nothing I have ever seen before and I am at a loss how to remove it.
Break any varnish seal around the latch on the door edge, find something that will fit inside the knob hole to act as a punch and smack it with a hammer. Once you push it out a bit any pliers should allow you to pull it the rest of the way.
Hint: a disposal wrench may work as the punch.
That hole looks a bit undersized so you may have to modify both holes to mount a new lock. I predict you will utter some new words as you work on that.
The way that I have found easiest was to use a 1/4 inch drive ratchet with a small socket on it, insert in the big hole, with the socket against the latch, then a big screwdriver to lever against the ratchet, pushing the latch out far enough to grab with locking pliers, then pull.
ED
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
