Help Removing An Iron Door! - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 01:36 PM   #1
Help Removing an iron door!
Hi everyone! I've been trying, to no avail, to remove this iron/metal door from my den. We never use it and have to tie it open because otherwise my door can't get through her doggy door.
Since we're fixing up the den and it's no longer our junk area, we'd really like to remove this door once and for all.
But the pins won't come out and the hinges have these funny looking screws. I have no idea how to remove this door.
Here is a picture of the hinge:
JMar0408 is offline   Reply With Quote
Old 06-21-2011, 05:11 PM   #2
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Here is a conversation about it: http://www.doityourself.com/forum/ar.../t-208293.html . Options are: special tool, drill them out, cut slots for driver, etc.... Personally, I've always just taken an angle grinder to the heads.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 06-21-2011, 05:20 PM   #3
aha! unbelievable did not think there could be a tool to remove those one-way screws.
THANKS! can't wait to get to Home Depot. Now I just hope the paint over them won't be an issue. I'll let you know how it goes!
Old 06-22-2011, 07:56 AM   #4
Yep, those are security screws, to prevent removing them. Those probably are also security hinges, that will not allow the pins to be removed. What he said, cut screwdriver slots in the screws with a hacksaw or similar, or grind off the heads.
Don't toss that door, it looks like it may be worth something.
Old 06-22-2011, 09:13 AM   #5
hehe i won't toss it. I'll store it in our shed. It's just in the way right now. We've had it tied open for 4 years straight (ever since we got our dog). It is a beautiful door, just not practical for the time being.
I got the bit for my drill last night. About to put it to work now!
Old 06-22-2011, 09:27 AM   #6
ok got the screws to come out about 1/4" . But at least now I know they move thanks to you guys! I'm going to try to cut some slots into them to finish removing them since they won't budge when i take pliers to them. I'm a bit of a weakling, what can i say?
Old 06-22-2011, 03:37 PM   #7
Oldguy
Rehabber's Avatar
once they are 1/4"out, vise grips will remove them easily
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
The Following User Says Thank You to Rehabber For This Useful Post:
HomeSealed (06-22-2011)
Old 06-22-2011, 04:24 PM   #8
oh nice! thanks..... i went back to painting the den... got tired of trying. i actually have two vise grips so let me go give that a try after i take a break.
Old 06-22-2011, 04:39 PM   #9
SUCCESS!!! well one hinge lol
JMar: 1 Iron Door: 0
Thanks for all the great suggestions. This forum is awesome. I actually learned a thing or two! =)
Leaking Door JaneD Windows and Doors 2 06-15-2011 09:22 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 04:47 PM
removing cast iron wye joint diy718 Plumbing 5 10-25-2010 06:32 PM
Security screen door dangerp Carpentry 4 09-22-2010 08:02 PM
Sheetrock put on w/o removing door trim Carla33 Carpentry 13 12-26-2009 02:32 AM
