Help With New French Door... House Already Shift? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-10-2011, 04:51 PM   #1
Help with new French Door... house already shift?
Ok, I put a new frame and french door in about 3 months ago in the freezing chicago winter.... its been perfectly fine ever since.
The past couple of days the door opens and closes just fine and is still perfectly spaced gaps around the door... but the pad lock and door handle seem to have moved 1/4" lower then the holes for them to lock into!
I have so pull up on the door to get the door to lock.
What's going on?
Integraoligist is offline   Reply With Quote
Old 04-10-2011, 04:59 PM   #2
DIY staff
Rewards Points: 7,174
Is it hinged to the center or into one of the side jambs?
You say that the revel around the door is still perfect all around the door /jamb --
Yet you are able to lift the door 1/4 inch to make the latch operate---something doesn't add up--
Post a picture---Mike---
Old 04-10-2011, 05:12 PM   #3
I will when I get home in a few hours. Thanks!
Old 04-11-2011, 12:00 AM   #4
Ok, here are a few pics
Old 04-11-2011, 09:04 AM   #5
Old School
Willie T's Avatar
Where are the shims?
Willie T
The Following User Says Thank You to Willie T For This Useful Post:
tcleve4911 (04-11-2011)
Old 04-11-2011, 09:07 AM   #6
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
.....and did you use a 3-4" screw in the hinges to secure the jamb to the framing?
tcleve4911 is offline   Reply With Quote
Old 04-11-2011, 09:23 AM   #7
The shims are there, I followed the directions exact (at least i think)
Yes I used 3" screws.
Old 04-11-2011, 11:54 AM   #8
Rewards Points: 5,336
What's going on?
Either the right side dropped or the left side lifted up.
How was the exterior sealed? Is it possible water got in the left side and caused the floor to swell?
If one side is lower then the other, the frame could have shifted on you.
Are the corners square?
The jambs plumb?
This would cause the reveals to not be perfect, though.
Ron
Old 04-12-2011, 09:52 PM   #9
The jambs plumb?
Ron
It is on concrete, I checked for cracks and shifting but there are none. Everything is showing up square and perfect just like when I installed it. Its as if someone redrilled the holes and moved the lock higher just to iratate me.
Old 04-13-2011, 07:50 AM   #10
So, the locks were all lined up and functioning at one point. And then they were off by a 1/4" and not working, but the frame is all square and the reveals are all perfect.
This isn't possible on this planet. You're missing something.
Ron
Old 04-13-2011, 08:22 AM   #11
kwikfishron's Avatar
Rewards Points: 210
How about a picture standing back showing the whole door.
kwikfishron is online now   Reply With Quote
Old 04-13-2011, 08:45 AM   #12
Ron
Exactly, I just know what im missing
I will get a full pic up shortly.
Old 04-13-2011, 08:59 AM   #13
If you know what you're missing, what's the issue? Just fix it.
Ron
Old 04-13-2011, 09:32 AM   #14
Ron
Damn droid not putting all the words in... add the word DON'T in there.
Existing French Drain Question chrisswany Landscaping & Lawn Care 4 08-17-2010 11:55 AM
Do I need to waterproof my basement if I already have a french drain? buratti Building & Construction 4 03-20-2010 04:32 PM
Berm and/or French Drain Solution?? (Pictures Included) appleman01 Landscaping & Lawn Care 9 03-20-2010 10:37 AM
French Drain Solution? Any Help Would Be Great! gregt848 General DIY Discussions 2 08-01-2008 10:16 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
