Help with new French Door... house already shift?
Ok, I put a new frame and french door in about 3 months ago in the freezing chicago winter.... its been perfectly fine ever since.
The past couple of days the door opens and closes just fine and is still perfectly spaced gaps around the door... but the pad lock and door handle seem to have moved 1/4" lower then the holes for them to lock into! I have so pull up on the door to get the door to lock. What's going on? |
Is it hinged to the center or into one of the side jambs?
You say that the revel around the door is still perfect all around the door /jamb -- Yet you are able to lift the door 1/4 inch to make the latch operate---something doesn't add up-- Post a picture---Mike--- |
I will when I get home in a few hours. Thanks!
Where are the shims?
.....and did you use a 3-4" screw in the hinges to secure the jamb to the framing?
How was the exterior sealed? Is it possible water got in the left side and caused the floor to swell? If one side is lower then the other, the frame could have shifted on you. Are the corners square? The jambs plumb? This would cause the reveals to not be perfect, though. Ron |
So, the locks were all lined up and functioning at one point. And then they were off by a 1/4" and not working, but the frame is all square and the reveals are all perfect.
This isn't possible on this planet. You're missing something. Ron |
How about a picture standing back showing the whole door.
I will get a full pic up shortly. |
Ron |
| All times are GMT -4. The time now is 03:42 PM. |
