-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Help with new construction window install (http://www.diychatroom.com/f104/help-new-construction-window-install-118326/)
pac127 09-26-2011 07:43 AM
Am looking to install Anderson double hung new construction windows into an existing opening, replacing older single hung windows (that have old wood window sills and exterior trim that I want to eliminate/replace).
Most of the research/guides/videos I've viewed show in detail the install procedure when the siding hasn't yet been installed, i.e. showing Tyvek over framing.
1. Once I have the window in I need to flash it. Most sites recommend installing 4" flashing around the entire window, however the gap over existing rough opening to siding is 2 1/4". Is this enough of an overlap. If not what's recommended ?
2. Some sites say not to flash below the sill. Some say you should. Which is right? (I know not to caulk at the bottom).
3. I would like to install a sill pan. Am I right in thinking if the sill pan has a back dam then I will need to use some kind of non-organic flat shims to raise the window above the height of the back edge ?
Any other advise on this type of install would be really appreciated ...
Windows on Wash 09-26-2011 08:36 AM
http://www.youtube.com/watch?v=KpqJxbk5qwc
