Help Identifying Window Manufacturer - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-14-2013, 02:15 PM   #1
Rewards Points: 165
We'd like to add screens to a couple windows on our home. The house was renovated to the studs last year (before we bought it) and new double hung windows were installed at that time. Before building my own or ordering custom ones I figured I'd at least see if I could track down the manufacturer and see if they were available for order. The ONLY information I can find on them is a sticker at the very top of the upper sash. There is no engraving on the glass, or the aluminum seal between the panes. I've done some googling and come up empty handed. Any help or advice on how to proceed?
red92s is offline   Reply With Quote
Old 09-16-2013, 06:11 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,954
Post a picture from further back.
Window material?
Old 09-16-2013, 08:21 AM   #3
Rewards Points: 13,300
Do the sashes tip down for cleaning? If so tip them and look on all sides for some markings or a sticker.
Nothing on the latch?
Old 09-16-2013, 09:01 AM   #4
Rewards Points: 165
Didn't think to check the latch. Good call.
They do tip out for cleaning. I've only checked the lower sash on one window but couldn't find any identifying features.
The sashes are wood. The rails on the sides that house the mechanicals are vinyl. Fairly safe to assume these are a basic builder grade window, as everything else in the house is. Additional pictures coming.
Old 09-16-2013, 09:14 AM   #5
Rewards Points: 165
Here is a shot from the outside. The guy at Lowe's said he thought it looked like a Jeld Wen?
Old 09-16-2013, 02:12 PM   #6
Home Performance
HomeSealed's Avatar
Rewards Points: 712
This is the only wood product that I came up with when I searched the model numbers. Hope it helps...
If not, as mentioned above, tilt in the sashes and look for another sticker.
http://tuckerdoor.com/LinkClick.aspx...id=106&mid=477
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 09-16-2013, 02:57 PM   #7
Rewards Points: 165
That's actually a semi-local company, so it's a strong possibility. Found a Jeld Wen screen at HD that is the perfect size, with the spring plungers on it. May just order those in a different shade to match existing trim.
Old 09-16-2013, 04:13 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Sounds like a good solution.
www.HomeSealed.com
Old 09-16-2013, 06:54 PM   #9
Looks like they are well maintained.
uPVC window handle won't close window properly, how can I fix it? Epimenides Windows and Doors 4 02-10-2013 03:09 PM
how to deal with a window in a shower MLMIB Kitchen & Bath Remodeling 9 09-12-2012 09:41 AM
Window Manufacturer for warranty? secutanudu Building & Construction 3 04-18-2010 08:31 PM
How to 'finish' outside of replacement window? KatieAK Building & Construction 9 04-02-2010 07:37 AM
Replace old window with smaller window Suncrest79 Building & Construction 3 04-15-2009 09:39 PM
