HELP: Garage Door Rails Above Rafters In Outbuilding. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-13-2011, 08:36 PM   #1
HELP: Garage Door rails above rafters in outbuilding.
When I purchased my house around 1 year ago, I knew there were several more improvements I wanted to accomplish. The house had a small deck that was built in between the end of the driveway and my outbuilding. If the deck was removed, and the driveway extended, then I would be able to use my "outbuilding" as a garage. This spring, I tore my deck off of the house, and I am having the driveway extended 40 feet to the building this week. As I am making improvements to make the garage door usable, I found that the door rails actually run above the rafters due to the low ceiling height in the building. I am looking for some help on a type of garage door opener that I may be able to use. When the door is raised, the clearance between the door and the top of the rafter is just an inch or two. The rafters run from side to side in the building. I know that the typical L type bracket would not have clearance from the rafters. If anyone may have any words of advice or know where to point me, I would greatly appreciate it. Thanks.
kptff is offline   Reply With Quote
Old 03-14-2011, 07:43 AM   #2
How low is "low"??? There are usually low headroom kits for most garage doors, but there is a limit for even those. If the door clears by anything, then it fits, but you can't install an opener.
Old 03-14-2011, 08:35 AM   #3
The ceiling height is probably 8 feet...I can walk around fine in it. The only issue is with the door/rails going above the rafters. I was thinking I may be able to build a brace to suspend the garage door opener above the rafters/rails, but I wasn't sure of the different type of systems that attach to the door itself, other then the L bracket.
Old 03-15-2011, 08:03 AM   #4
Low headroom door tracks........
Old 03-21-2011, 08:03 AM   #5
Household Handyman
Rewards Points: 1,408
Now I am really confused on this one: I understand almost everything until you state that the rafters run "from side to side in this building". Somehow I get the picture that your garage door opens at right angle to the existing rafters, and IF SO: how could the tracks even work if they are placed above the rafters? This is a situation where a photo would be worth a zillion words.
Old 03-21-2011, 08:37 AM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 208
If all else fails install a roll up door.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-08-2011, 02:14 PM   #7
If read your post correctly?
You are asking what kind of opener to uses with a low headroom system?
You can use the Liftmaster 3800 only if you have a torsion spring system, If you don't have a torsion system, then you will have to use a different system.
Here is a link to the 3800 below. (it only needs 3" of headroom)
http://garage-doors-and-parts.com/li...r-openers.html
I hope that this helps out, If I am wrong about looking for an opener, I apoligize for misunderstanding the bottom part of your message.
Wade
sumnerw is offline   Reply With Quote
Tags
garage , garage door opener , out building , outbuilding
Garage rafters proctrc Building & Construction 5 06-13-2010 08:40 PM
Raising ceiling (rafters) in detached garage acme54321 Building & Construction 15 05-21-2010 10:21 PM
garage roof insulation between rafters denverman71 Building & Construction 1 10-21-2009 01:06 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
Replace Missing Garage Rafters Parrotheadrik Building & Construction 4 05-02-2008 08:29 AM
