Help: Front Door Kicked In - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-04-2014, 06:08 PM   #1
Rewards Points: 422
Help: Front door kicked in
My daughter's front door was kicked in, and the jamb is all damaged and split. Since it's a prehung door(I assume), does the entire unit have to be replaced? Or can it be repaired somehow? It's a townhouse built around 2000. Thanks.
Jim McC is offline   Reply With Quote
Old 02-04-2014, 06:54 PM   #2
Jb1234's Avatar
Rewards Points: 87
Well I guess the main question I have to ask is, was this a result of horseplay or was it a crime? If it was someone kicking in to do a burglary, etc., I think you probably would answer your own question with replace. Then install a security anti-kick plate for the deadbolt and make sure the screws go all the way into the framing. I'm actually a cop, so I have seen all the different ways houses are broken in to. The old front door kick is still pretty popular. Usually the striker plate is blown right out of the jamb as a result of the deadbolt being forced through the jamb. I'd think that jamb would always be weak no matter how you tried to mend it. My front door would take a ram to knock down, and then they'd be greeted by the 3 pups in my picture.
But back on topic, without seeing a picture, the best I could answer would be "maybe" it could be fixed. If this was an interior door, sure. But exterior, no way. Upgrade and protect that baby girl.
Something like this is a good start.
http://m.homedepot.com/p/First-Watch...005/202799866/
Jb1234 is offline   Reply With Quote
Old 02-04-2014, 06:55 PM   #3
DIY staff
Rewards Points: 7,174
I've fixed a few mangled jambs----I've never run across one that couldn't be repaired----but my carpentry skills and tool collection is above average--
How handy are you? What tools do you have at your disposal?
Old 02-04-2014, 09:20 PM   #4
Rewards Points: 422
It was horseplay, so to speak. Not handy enough to fix this. That's why I didn't even know if it could be fixed.
Old 02-04-2014, 09:22 PM   #5
Jb1234's Avatar
Rewards Points: 87
Well at least that part is good news. Unless your girl was the boot kicker whoever did the damage better pony up. Ha.
The Following User Says Thank You to Jb1234 For This Useful Post:
gregzoll (02-05-2014)
Old 02-04-2014, 09:35 PM   #6
Gymschu's Avatar
Rewards Points: 938
The quick and easy fix is to use a multi-tool to cut out the damaged section of the wood jam. That's usually 2 or 3 feet of the jam. Then you need a replacement piece with the same dimension of what you cut out. Nail that into the studs. Drill new holes for the lock and deadbolt with a spade bit. Replace the mangled metal of the latch and deadbolt latch. It won't be pretty, but it will get you by til you can buy a new door.
Gymschu is online now   Reply With Quote
The Following 3 Users Say Thank You to Gymschu For This Useful Post:
gregzoll (02-05-2014), oh'mike (02-05-2014), Windows on Wash (02-05-2014)
Old 02-04-2014, 11:14 PM   #7
Rewards Points: 422
Old 02-05-2014, 10:41 AM   #8
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,276
Get to chopping and sanding.
Old 02-05-2014, 04:20 PM   #9
Google dutchman door repair. Not too difficult.
mknasa dad is offline   Reply With Quote
Old 02-05-2014, 11:16 PM   #10
Rewards Points: 52
i recommend a striker reinforcement plate to prevent kick in.
bklynsoulja is offline   Reply With Quote
Old 02-06-2014, 09:21 AM   #11
Davejss's Avatar
Rewards Points: 776
I'd replace the whole thing.
Davejss is offline   Reply With Quote
Old 02-06-2014, 10:30 AM   #12
Rewards Points: 422
Good idea. Is there a plate that will cover both strike plates? Deadbolt and door knob? It seems they're all for deadbolt only?
Squaring a walkway off the front steps? Boiler98 Building & Construction 3 07-14-2012 08:31 PM
Replacing a concrete front door approach with a boardwalk? bigdaddydavy Building & Construction 10 05-31-2012 09:08 PM
Help with paint colour for the garage and front door syndicate1 Interior Decorating 7 07-25-2010 06:08 PM
Front Cement Steps / Porch Leaking bschwarz Building & Construction 2 04-14-2009 10:46 PM
Adding new Front Porch, need opinions MeraleeCrowl Remodeling 1 11-05-2008 12:47 PM
