Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 08-04-2011, 10:38 AM   #1
help: Finishing window (pictures)
I am wondering how I could go about finishing my basement window. I am a first time renovator and am looking to tackle this job by myself. I am fairly handy with a access to the tools needed to finish the job.
After some research I read some different responses on how to finish it, but have finally been able to snap some pictures to get maybe a more detailed answer from the community. I am familiar of how to case the window I am mainly wondering how I would go about filling the gap between the frame and the lip of the window.
Anyways I will just post pictures from now and see where that goes. I appreciate all the input and help you all can give me.
vanynh is offline   Reply With Quote
Old 08-04-2011, 10:41 AM   #2
If you are talking about the area over the insulation I think it would look best to Sheetrock it.
Broughton is offline   Reply With Quote
Old 08-04-2011, 11:03 AM   #3
either sheetrock like Broughton said or make jamb extensions and trim it out
Old 08-04-2011, 11:16 AM   #4
Moderator
kwikfishron's Avatar
Remove the existing jamb and build a new one that comes out flush with the sheetrock if you’re just simply going to picture frame the trim.
-NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State.
kwikfishron is offline   Reply With Quote
The Following User Says Thank You to kwikfishron For This Useful Post:
HomeSealed (08-04-2011)
Old 08-04-2011, 12:49 PM   #5
So if I sheet rock it, won't it be like 1 step down from the current window sill? Will I have to raise the sheet rock up somehow? like lay a piece of mdf or something all around and then sheet rock on top of that?
Or am I to tuck the sheet rock tight under the gaps between the edge of the window and the sheetrock?
Does this make sense?
Thanks for all the replies so far!
Old 08-04-2011, 02:08 PM   #6
the windows in my house were drywalled on the inside but had marble sills on the bottom. where the drywall met the windows they installed small trim around 3 sides but i ripped all that out to put jambs in and trim around them because they looked so plain. but the drywall and molding would work in your case.
Old 08-04-2011, 02:13 PM   #7
I would just but the drywall up to the jamb and the caulk and paint the joint, very clean looking. There will be a small reveal but I think it would look fine.
Old 08-04-2011, 02:46 PM   #8
Moderator
You’re kidding, right.
-NEW MEMBERS-
Old 08-04-2011, 02:49 PM   #9
I wasn't but now I want to act like I was! Did I suggest a technical or aesthetic faux pas?
Old 08-04-2011, 03:21 PM   #10
sooo up to the jamb or slide it right under?
Transom window repair options (with pictures) barlav Windows and Doors 4 06-14-2011 07:31 AM
Window Stool Removal Issue bperk21 Windows and Doors 4 04-21-2011 07:03 PM
Window Pane Replacement rjschwar Building & Construction 3 08-27-2010 08:15 AM
Bathroom window issues? Mantaray14 Remodeling 11 12-04-2009 08:40 PM
Window jamb helpless handyman Carpentry 11 08-03-2006 01:45 PM
