-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   help: Finishing window (pictures) (http://www.diychatroom.com/f104/help-finishing-window-pictures-112914/)
vanynh 08-04-2011 10:38 AM
I am wondering how I could go about finishing my basement window. I am a first time renovator and am looking to tackle this job by myself. I am fairly handy with a access to the tools needed to finish the job.
After some research I read some different responses on how to finish it, but have finally been able to snap some pictures to get maybe a more detailed answer from the community. I am familiar of how to case the window I am mainly wondering how I would go about filling the gap between the frame and the lip of the window.
Anyways I will just post pictures from now and see where that goes. I appreciate all the input and help you all can give me.
http://i51.tinypic.com/fcqwwg.jpg
http://i55.tinypic.com/ayncap.jpg
Broughton 08-04-2011 10:41 AM
If you are talking about the area over the insulation I think it would look best to Sheetrock it.
DannyT 08-04-2011 11:03 AM
either sheetrock like Broughton said or make jamb extensions and trim it out
kwikfishron 08-04-2011 11:16 AM
Remove the existing jamb and build a new one that comes out flush with the sheetrock if you’re just simply going to picture frame the trim.
vanynh 08-04-2011 12:49 PM
So if I sheet rock it, won't it be like 1 step down from the current window sill? Will I have to raise the sheet rock up somehow? like lay a piece of mdf or something all around and then sheet rock on top of that?
Or am I to tuck the sheet rock tight under the gaps between the edge of the window and the sheetrock?
Does this make sense?
Thanks for all the replies so far!
DannyT 08-04-2011 02:08 PM
the windows in my house were drywalled on the inside but had marble sills on the bottom. where the drywall met the windows they installed small trim around 3 sides but i ripped all that out to put jambs in and trim around them because they looked so plain. but the drywall and molding would work in your case.
Broughton 08-04-2011 02:13 PM
I would just but the drywall up to the jamb and the caulk and paint the joint, very clean looking. There will be a small reveal but I think it would look fine.
kwikfishron 08-04-2011 02:46 PM
:eek:
You’re kidding, right. :laughing:
Broughton 08-04-2011 02:49 PM
I wasn't but now I want to act like I was! Did I suggest a technical or aesthetic faux pas?
vanynh 08-04-2011 03:21 PM
sooo up to the jamb or slide it right under?
