Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 10-25-2012, 01:13 PM   #1
Help with finding weatherstripping for my old (mid 1960's) wood sash double hungs!
Well, winter is upon us once again. I am making an honest effort to seal up the windows to make the house more comfortable. I took the sashes out of my sons windows and found the vinyl strip between the sashes where the lock is located to be completely deteriorated and needing replacement. I have a picture of one I took out of a different window for reference.
I have had no luck finding a replacement for this stuff, what is the alternative solution for sealing between the panes? This vinyl trim is also along the bottom of the lower sash. I figured I could just replace that with decent quality foam or felt.
Thoughts?
Thanks all.
240sx4u is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Double-hung window sash glass replacement teetee1 Windows and Doors 1 03-10-2012 12:21 PM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
How to disassemble aluminum clad wood window sash? JohnBinSC General Discussion 6 01-17-2011 06:59 AM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
