Help with exterior door...
Sounds like you are more concerned with security as opposed to "sealing"? If so, do what Joe said and just cut down a solid door to fit. If you would prefer something with a decent fit and finish, you are going to be stuck ordering a 30" door with a custom height cut-down.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. , To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
