-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   Help with door astragal (http://www.diychatroom.com/f104/help-door-astragal-103120/)
NABRIL 04-29-2011 01:44 PM
16 Attachment(s)
hello
new to forum...looks great.
I recently replaced the 2 doors to my master bedroom; they consist of 2 doors with an astragal in the middle. Unfortunately, the opening made by the previous owner is about 1/4 inch too wide. So when you look at the closed doors from the inside, you see (in this order):
Left door edge, 1/4 inch gap, 1/4 inch astragal nailed to right door.
So I ask, what can I do to eliminate that 1/4 inch gap? Are thicker astragals available that I can use to close that gap?
It's not horribly ugly, but kind of a pain to see that gap. A visit to Lowes yesterday gave me an idea to put a 1/4 inch molding in between the astragal and the right door, and then caulk the edges.
Any suggestions?
oh'mike 04-29-2011 02:13 PM
A picture would help-----
I assume that you don't have any advanced wood working tools or skills----Making a new astragal
would be the natural thing to do if you have the tools.---Overlaying a thin strip on top of the existing work will do if you are neat.---Mike----
NABRIL 04-29-2011 02:37 PM
16 Attachment(s)
THANKS oh mike
Yes, I meant to upload a picture, but I am at work at the moment.
No, I dont own many tools. But your thought is to make one myself if I had the tools right? Get a thin piece of wood and mold it to look like a T?
Was that your thought? Wait. You meant to lay a thin strip on top of my right door. BUt then I will have a 1/2 inch gap between doors, no?
oh'mike 05-01-2011 08:11 AM
I would make a new T-shaped piece---Very easy do do with a table saw and a router----
Not so easy if you don't have access to those two tools.
---good luck,Mike---
epson 05-01-2011 09:08 AM
I believe you can get a (T) Astragal in aluminum and bronze if you don’t have tools to make your own. Just a thought…
NABRIL 05-01-2011 07:20 PM
16 Attachment(s)
thank you both. I attached a pic to better illustrate; the pic was taken from the inside of the bedroom.
Since I dont have the tools and perhaps knowledge, I am thinking the easiest way to get rid of that gap (the vertical black line in the pic) is to nail a 1/4" straight molding to the left door. I've looked for astragals online, but havent cross across too many companies.
My concerns with adding the molding are:
1) How do you hide the small gaps between it and the door. I have the same concern with the gaps between the right door and the existing astragal. How do you seal that up? Caulking?
2) If I add that molding to the left door, what happens to the deadbolt that now sticks out perfectly out of the door. Would I have to use one with a different backset to compensate for the additional width?
oh'mike 05-01-2011 08:02 PM
If you add a 1/4" strip to fill the gap---add it to the astragal--not the door---
NABRIL 05-01-2011 08:07 PM
16 Attachment(s)
right
Loud duh to myself.
How do I fill in the gaps between additional molding and astragal and door? What do I use?
oh'mike 05-01-2011 08:17 PM
If it's to be painted use latex painters caulk.
If it is to be stained and varnished---Just make it perfect to begin with--:laughing:
