Heat Resistant Tint? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-01-2011, 11:47 PM   #1
Heat resistant tint?
I'm in a E/W facing home and would like to get something to help avoid the sun completely heating my room due to the direct sunlight coming into the windows.
I'm wondering if there is some kind of tint I can use, or something I can add onto the outside of the window that will help reflect the massively hot sun.
I live in AZ, and when it's 120 degrees outside, it REALLY beats down on the windows.
Is there something I can do without buying completely new windows?
mrbobdou is offline   Reply With Quote
Old 07-02-2011, 01:11 AM   #2
Household Handyman
Rewards Points: 1,408
There are window films available at the apron stores (Lowe's, HD) which will block out some of the UV rays which create the heat in a room. I did a room at my son's house which was my new grandson's some years back. The film looks to be "mirror-ish" from the outside, and definitely darkened the room from the inside. Putting it on was very easy once I did a few panels. There are other types of this film also available from other sources.
Old 07-02-2011, 09:40 AM   #3
Custom Home Builder
3M makes a sun blocking tint.
Only problem is you have to have it installed by an authorized installer.
If the company knows what they are doing, it will look like the windows came that way.
A little pricey but should be worth it.
Especially where you live.
thomasjmarino is offline   Reply With Quote
Old 07-03-2011, 02:47 PM   #4
Do you know of any specific ones to search for?
I've found some stuff like http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 but I want something more specific for heat resistant, rather than making it impossible to see inside.
Old 07-04-2011, 02:20 PM   #5
Window Repair Guy
No Such Thing!
There is a absolutely no such thing as heat resistant window tint. Window tinting only provides somewhat of a superficial protection from glare. If you want true energy efficient heat resistance Windows you need to get Windows with low E coatings such as ???????? which is a residential low E capable of breaking down the ultraviolet rays, infrared rays and many of the other harmful rays produced by the sun. This coating is generally applied on the exterior pane in between the glass which is referred to as surface two. This keeps the sun's rays from penetrating into the glass unit unlike conventional window tinting which is applied to the interior pane. This traps heat within the panes of glass generally resulting in seal failure. It is wise to do much research before putting tint on your Windows as this usually voids any warranty that the manufacturer supplies.
Last edited by oh'mike; 07-04-2011 at 03:00 PM. Reason: removed ad link--stop spamming or get banned
windowrepairguy is offline   Reply With Quote
Old 07-05-2011, 07:50 PM   #6
Well.. any other ideas?
VisionPRO Setup Functions & Heat Pump infoskr HVAC 43 07-12-2015 04:28 PM
heat resistant lamp mrsmith4422 Electrical 1 10-27-2010 11:15 AM
Comparison and Heat Pump Selection help... ChrisDIY HVAC 7 03-06-2010 08:34 PM
Heat Pump Woes Zenica HVAC 50 01-27-2009 07:37 AM
Which diagram to use on Lenox Thermostat wiring setup? Heat Pump Lenox techs needed twilightcall HVAC 1 08-13-2008 11:49 AM
