Hanging A Slab Exterior Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 06:02 PM   #1
Hanging a slab exterior door
My current front door is sagging due to worn out screw holes, it is the original door and the house was built in 1972.
I purchased a new front door but it is a slab door and my old jams are worn out
I have been told that I can get a millwork shop to actually prehang my slab door so that it will be much easier to install.
Is this good advice and how much should I expect to pay to have this done
I am pretty certain that I can handel installing the door once it is prehung.
If it matteres, I live in Rockdale County Georgia, a suburb of Atlanta. I would welcomne recommendations of a shop that can do this for me.
thanks, Tom
bonshawscots is offline   Reply With Quote
Old 03-15-2011, 07:00 AM   #2
You could probably save the original door, if you want to. Replace the jamb side hinge screws with #12 3" screws into the house framing. That will tighten up the jamb side nicely. If the door side screws are stripped out, drill them out to 1/4", insert dowels slathered with Titebond II glue and redrill for slightly longer screws.
If you decide on the new door, same things with longer screws on the jamb side. But consider a prehung door. Probably cheaper that having a shop do it, and weatherstripped better, with a threshold to match.
Old 03-15-2011, 02:48 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
I agree with Bill... Anything can be done, but by the time you have someone construct a proper frame, weatherstrip it, and hang the door, you will probably have paid more and have a less polished finished product then if you'd just bought a prehung in the first place. Is the slab returnable, or was it a craigslist deal or something?
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 11:16 AM
raised slab foundation tclark Building & Construction 6 01-07-2011 08:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 08:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 12:50 PM
