Hanging Exterior Doors - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-10-2012, 01:20 AM   #1
I have an old house and the exterior doors need replacing but the frames are fine can I just replace the doors with new ones
Fhare3 is offline   Reply With Quote
Old 03-10-2012, 03:06 AM   #2
Disabled wood vet
titanoman's Avatar
Rewards Points: 1,004
Yes....
titanoman is offline   Reply With Quote
Old 03-10-2012, 07:37 AM   #3
Can you, certainly, should you, it would not be my recommendation. If you measure CAREFULLY, a new door slab is not too difficult to install. But a prehung door has the extra benefit of having all new weathstripping and an energy efficient sill. New trim on the insterior and exterior are usually needed, but while you are at it, the air space around the door can also be insulated.
The Following User Says Thank You to Just Bill For This Useful Post:
HomeSealed (03-11-2012)
Old 03-10-2012, 07:35 PM   #4
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,058
i completley agree with bill.... why spend money on just a new slab and then a couple years down the road have a leak which is because the frame is starting to get bad and allowing water into the house.. do it right replace the whole thing
woodworkbykirk is offline   Reply With Quote
Old 03-10-2012, 08:21 PM   #5
Tom Struble's Avatar
Rewards Points: 2,002
ya see some pretty junky wood on most pre hung door frames these days,i'd take an old solid frame with an interlocking weather stripping any day
Tom Struble is offline   Reply With Quote
Old 03-11-2012, 04:04 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,784
+1
Most of the older stuff is certainly better than most of the newer stuff.
another method of hanging ceiling drywall? shtoink Drywall & Plaster 22 09-21-2012 10:50 AM
Drywall hanging HELP!! topflitecop21 Building & Construction 8 01-16-2012 10:21 PM
Hanging a Heavy Mirror frapha1 General DIY Discussions 6 01-03-2010 12:21 PM
hanging Mirir on door txmike Carpentry 9 08-02-2009 10:01 AM
Hanging punching bag in garage Isocene General DIY Discussions 3 05-21-2009 09:20 AM
