Good Place To Get Custom/odd Windows? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-12-2011, 03:26 PM   #1
Rewards Points: 370
good place to get custom/odd windows?
I have an old round decorative wooden window that is leaking and rotting in the attic so it needs to be replaced. the rough opening between the framing around it is 21.5" x 22", any idea's on good places to get a reasonably priced replacement? I'd like to match it and it has a colonial grille. Bonus points for double pane low E etc. choices. I asked home depot and the best they could figure was over 1k.
Thanks.
MLMIB is offline   Reply With Quote
Old 03-12-2011, 03:50 PM   #2
the Musigician
DangerMouse's Avatar
Are you saying they said $1,000 for a window????
I'd make my own for free.... but then again, this IS a DIY forum....
Do you have pictures of this window?
DM
Old 03-12-2011, 08:56 PM   #3
Rewards Points: 370
window below, any help much appreciated
Old 03-12-2011, 11:20 PM   #4
DIY staff
Rewards Points: 7,174
You picture didn't post--------------
Have you tried a regular window and millwork place? A big box store typically only has a small selection-
look for a company that specializes in windows and doors. That price look very high.
Old 03-13-2011, 08:53 AM   #5
Rewards Points: 370
fixed, thank you
Old 03-13-2011, 09:00 AM   #6
the Musigician
Have you been up there to physically inspect it? It may be repairable/paintable?
It doesn't look that bad to me.
DM
Old 03-13-2011, 10:09 AM   #7
Rewards Points: 370
taken sideways, so the rotted out part is the bottom.
The wood doesn't even connect all the way. I'm sure I can, and if I can't find a reasonable replaced, I'm sure I will go up and scrap the paint off, get a wood epoxy fixer for boats and use it to shore up the window for a few more years, I just figured if I can get a better R value window I should and save myself the hassle of trying to fix this one since I think it's running past it's useful life and I want to stop the rot problem that could spread to structural parts.
thanks for the help
Old 03-13-2011, 10:16 AM   #8
the Musigician
Your idea for a temporary fix makes the most sense. I'd go that route while I searched for a replacement that does not cost a thousand dollars!
DM
Festool. Any one know a good place to buy slickgt1 Tools 3 04-19-2010 02:57 PM
Basement windows above floor joists billthecat Building & Construction 7 10-20-2008 09:07 AM
First time vinyl siding newbie plus windows justdon Remodeling 9 02-06-2008 07:39 PM
Replacing "Aluminum Flared" Windows? bahaisamurai Building & Construction 6 06-07-2007 11:23 AM
How do I install new windows? RickT Carpentry 17 10-12-2006 07:06 PM
