Glass Insert For Interior Door - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 07:37 AM   #1
Glass insert for interior door
I have flat hollow core doors that I would like to update with a glass insert. Does anyone know of kits available or has anyone done this?
Anth is offline   Reply With Quote
Old 12-19-2011, 08:20 AM   #2
DIY staff
Rewards Points: 7,174
Those doors are so flimsy that cutting a hole for a glass insert might weaken the door beyond use.
Do you have a picture or a link to what you want these to look like?
Old 12-19-2011, 09:44 AM   #3
Rewards Points: 12,830
Is this an inside or outside door?
Is it wood, metal, fiberglass?
Old 12-19-2011, 11:33 AM   #4
Title should be interior door - tried to edit, doesn't seem to take. Appear to be hollow core wooden doors. Just don't like the flat doors and instead of replacing them I thought a frosted glass insert could add some interest.
Old 12-19-2011, 11:45 AM   #5
DIY staff
I fixed the title for you---You could try doing that---buy a cheap door to experiment on.
This may require a few tools that you don't own,however.
The skins on the door are very thin and easy to cut with a jig saw--or a knife,if you are careful.
Finding wood trim 1 3/8" wide to wrap the new hole will be the problem--a table saw might be required to rip a bit of wood to fit.
Then some trim to picture frame the opening.
Insert the glass and tack in a tiny 1/4 round to secure the glass--fairly simple but you may need to borrow a few tools to cut the trims.---Mike---
Old 12-19-2011, 11:00 PM   #6
Thanks for your help. I may give this a try if I feel ambitious.
Old 12-20-2011, 08:46 AM   #7
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 878
Post up some pictures of your progress.
I will have to agree with oh'mike in that the door are typically so flimsy that cutting out a big chunk of the middle usually renders them structurally unsound.
Old 12-27-2011, 11:29 PM   #8
I have done this to the bathroom door, not out of choice, but because I had to cut a hole in the door to get our son out of the bathroom!! A drawer was open and there was no other way in!!
Anyway, what I did was square out the hole that I had cut, and then ripped down 2x2 lumber that would fit between the two 1/8" panels on all 4 sides. This gave stability to the door. On these ripped pieces, I routered a channel around the edge 1/4" wide (maybe it was 1/8", can't remember) and the depth of the tempered glass. I installed those ripped pieces into the opening so that routered edge was available for the glass to fit into. Then I used clear caulk on that edge, and pressed the glass into it, cleaning all the extra off. I used some moulding around the window which nailed into those 2x pieces and gave a little extra ease of mind to the glass. I also used the moulding on the outside of the door.
I have no problem with stability on the door, and although not professional quality, I'm quite proud of it...
Oh, my door is 26" x 78" and I only put in an 18"x16" piece of glass in the upper section, not a piece that fits a majority of the door...
joeh is offline   Reply With Quote
Old 12-30-2011, 12:43 PM   #9
This can be done but by law, and for the safty ov wout family, the glass MUST be safty glass! Kits, with a Z bar sandwich frame and 1/8" tempered safty glass, are available by special order in various standard sizes to fit 1 3/4" and 1 3/8" doors. Try calling local glass shops or you might try big box home centers. This is,by far, the cleanest and eaziest option for a hollow core door.
Chris
glazierwood is offline   Reply With Quote
Niche, Glass shelf to back wall? wraiththe Tiling, ceramics, marble 0 12-15-2011 03:46 AM
Need Advice For Fun Project - liberating stained glass window jackson33 Building & Construction 9 03-08-2011 05:09 PM
Glass on greenhouse roof Flavio Building & Construction 16 07-15-2010 08:37 AM
Impact Windows & French Doors Matty16 Carpentry 6 06-22-2009 10:01 PM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
