Glass Door Won't Close - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 09:55 PM   #1
Rewards Points: 47
glass door won't close
When swung open it will not close upon returning to the closed position. It bangs against the door sill at the latch point. Also, it now binds at the lower point where it closes. In other words, it appears that the hinges may have come out a few thousandths of an inch causing the door to droop. What to do? thanx
jeffs55 is offline   Reply With Quote
Old 09-28-2011, 09:57 PM   #2
Rewards Points: 150
Remove old screw on applicable hinge and install a longer screw which will in essence lift the latch to plate connection.
OhioHomeDoctor is offline   Reply With Quote
Old 09-28-2011, 09:58 PM   #3
Rewards Points: 150
If that does not work let me know and i will tell you how to throw a hinge.
Old 09-29-2011, 08:11 AM   #4
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,952
+1
This.
Old 10-01-2011, 05:11 PM   #5
Rewards Points: 5,336
Is this a storm door with a pneumatic closer?
Ron
B. Franklin 1759
Condensation ring on Pella window captjackny HVAC 59 01-04-2012 08:08 PM
Replacing window sill, but now it's stuck. rosemonster Carpentry 25 01-25-2011 05:31 AM
Help with replacing some glass shonkster Building & Construction 5 03-12-2009 06:24 PM
Larson Storm Door Won't Close Snowbird Building & Construction 13 03-03-2009 04:01 AM
Double-paned window glass replacement maximizer Building & Construction 5 08-18-2008 01:06 PM
