Garage Door Track Support Replacement? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-26-2014, 11:10 PM   #1
Rewards Points: 177
Hello Everyone,
The 2x4's that support my metal garage door track are rotted. I'm trying to figure out the best way to replace them without making extra work and ensuring I get the door operating properly.
The pictures aren't the best, but I was hoping they would provide enough information. I was thinking I could simply close the garage door and support the track using some additional wood. Once secure, I was planning on removing the siding and metal track from the 2x4's, use a reciprocating saw to remove the 2x4's, and replace with pressure treated wood. Re-attach siding and track. I would obviously do one side at a time. Is this do-able? Or am I over-simplify this job? I would appreciate any comments/suggestions. Thank you
Garage Door Track Support Replacement?-img00450-20140726-1301.jpg   Garage Door Track Support Replacement?-img00449-20140726-1301.jpg
Jim Ignatowski is offline   Reply With Quote
Old 07-26-2014, 11:13 PM   #2
Rewards Points: 6,652
If they rotted, that means that water was allowed to get inside the wall. This job means that you are most likely going to have to remove the outside covering, and along with the Drywall.
The door opening on garages is going to be either a 2x6 or 2x6 doubled with a a double or triple header. Depending on who built it, and how the plans called for the build.
Not going to be an easy job. Especially since you have to take the door down, take down the tracks to do the job right. Place Plywood sheeting across the opening to keep people out of there, while the work is going on.
Old 07-27-2014, 09:23 AM   #3
Rewards Points: 6
Can't tell by the pics if the 2x4 is structural or a backer for the track. I think your idea will work. Take the tension off the springs before doing the work.
Dan
djlandkpl is online now   Reply With Quote
Old 07-27-2014, 10:15 AM   #4
Rewards Points: 177
Thanks for the responses. The 2x4's that support the track are definitely not structural, they're not even a single piece of wood, it's a 2'x4'x8' and then they pieced another section on top to make it flush with the ceiling. However, the previous post by gregzoll has me thinking about something else. The damage to the 2x4's is most likely carpenter ant damage as opposed to water. I'm wondering what the chances are that the 2x6's around the garage opening haven't been compromised too. I'm going to remove the drywall to see if I can get a better look at them.
The Following User Says Thank You to Jim Ignatowski For This Useful Post:
gregzoll (07-27-2014)
Tags
garage door , garage jamb , track
Garage Opener Replacement handy man88 Building & Construction 0 10-02-2013 12:07 AM
Garage light ballast replacement. bdresch Electrical 12 11-01-2012 12:59 PM
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Garage Door Repairs / Replacement Sierratoo General DIY Discussions 10 07-02-2011 07:29 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
