Garage Door Threshold - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-04-2011, 05:37 AM   #1
Garage door threshold
Hi guys....
Have an 18x 7 garage door with opener. When it rains with any velocity the door leaks underneath at the threshold. Not everywhere... Just certain spots but when it leaks it leaks alot! Any advice?
stoked91 is offline   Reply With Quote
Old 07-04-2011, 07:46 AM   #2
DIY staff
Rewards Points: 7,174
Most garage doors don't have a thresh hold----they just use a soft rubber sweep attached to the bottom of the door panel.
Sometimes the slab sags making the rubber sweep useless ----post a picture----Mike---
Old 07-04-2011, 08:32 AM   #3
Ya... That's exactly the problem... The slab isn't level in some spots so the water seeps right in... Flooding the inside of the garage.... Is there anything I can put down?
Old 07-04-2011, 08:49 AM   #4
DIY staff
I've seen door bottoms fitted with a heavy foam that is scribed to the slab---
I have had no luck finding the product,however.
I run into this problem regularly enough and simply don't know where to get that foam --Mike---
Old 07-04-2011, 09:17 AM   #5
I've seen the product called tsunami threshold .... Heard anything about it. Expensive but looks promising!
Old 07-04-2011, 09:51 AM   #6
DIY staff
Nope---got a link? I get a lot of odd ball requests in the course of a year--nice to know what's out there.--Mike---
Old 07-04-2011, 10:20 AM   #7
Tom Struble's Avatar
Rewards Points: 2,002
there are exrta thick weatherstrips avalible that sometimes help
Tom Struble is offline   Reply With Quote
Old 07-04-2011, 10:30 AM   #8
Rewards Points: 1,016
I used to get a lot of water under our 16' garage door in certain spots along the door when the wind would drive the wind just so. Installed a garage door threshold similar to at the link below - no problem whatsoever now for several years.
http://compare.ebay.com/like/2606769...Types&var=sbar
____________
Vince
Old 07-04-2011, 11:00 AM   #9
So I have looked around on the Internet. A threshold is definitely the way to go! Can't see any precipitation getting in. Now I just have to find out where to get one other than online.... Does Lowes or any other construction stores carry these thresholds?
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Garage Insulation yamster Insulation 0 07-01-2011 02:30 PM
Do I have a Fire Rating Issues with Attached Garage Perry401 Building & Construction 4 04-26-2011 12:58 AM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
