Garage Door Resurface - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 07-30-2012, 01:39 PM   #1
garage door resurface
I have an old garage door that I'd like to repair
Reason I want to repair is because the ground is unlevel and a new door wouldnt sit right at the moment (I think the concrete foundation has raised sunk with the frost thaw cycle here in new york)
door is still functional and opens/closes without issue
I've tried to repair some of the rot but its gone too far and would take a lot of mud and shaping to get right
anyway I was thinking to just veneer the entire door and make it completely flush with something thin like hardboard, plywood or formica?
It needs to be thin and weather resistant to last us another few years... what would be the most cost effective repair beside a new door? I'm talking maybe $60
Thanks in advance
RacerDave1 is offline   Reply With Quote
Old 07-30-2012, 06:12 PM   #2
Rewards Points: 12,830
That door is just not worth fixing!
A new door with a scribed to fit shim screwed to the bottom of it to get you by until you rip out that drive would work far better.
Old 07-30-2012, 06:28 PM   #3
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 880
While I would love to see the finished effort and what comes of it, I just don't think there is anything to even nail to there.
The Following User Says Thank You to Windows on Wash For This Useful Post:
HomeSealed (08-03-2012)
Old 07-31-2012, 05:31 PM   #4
First of all, thanks for the replies! I appreciate any criticism on this problem.
well, heres what I have got done so far
I cut a strip of wood and filled in where the rot was.
Replaced the rotten panel. Added some paint.
I figured if I was going to make it flush Id have to fix some of the rot
I like the result so far... I've only got about $20 invested
Probably just going to finish it up with another tub of wood filler and paint the whole door until I get another door.
Old 07-31-2012, 06:44 PM   #5
Rewards Points: 880
Some more feather sanding out of those undulations and a finish coat of paint might get you a pretty nice finished product.
Good work.
Post up the final pictures.
Old 08-02-2012, 03:56 PM   #6
wasnt able to feather it the way I would have liked because of time constraints but it did come out pretty decent.... looks even better from far away
Old 08-03-2012, 09:14 AM   #7
Rewards Points: 880
Good work.
Should buy you some more time before you swap it out.
Old 08-03-2012, 11:41 PM   #8
Home Performance
HomeSealed's Avatar
Rewards Points: 710
I was kinda hoping to see the formica option... Looks decent though. I'm sure that you realize that it is nothing more than a short term band-aid, but in that capacity you did a nice job.
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 02:50 PM
Garage Ideas? tripflex General DIY Discussions 13 12-16-2009 08:06 PM
