Garage Door Open And Close - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 11:51 PM   #1
garage door open and close
I've installed a new trolley. Door closes and then rises about a foot then stops.
andrepoitras is offline   Reply With Quote
Old 12-30-2012, 12:19 AM   #2
Missouri Bound's Avatar
More information please.....is this an opener problem or a spring problem?
Do you want it your way or the right way?
Old 12-30-2012, 12:31 AM   #3
Rewards Points: 12,830
What style spring is it?
http://ddmgaragedoors.com/diy-instru...leshooting.php
Old 12-30-2012, 10:15 AM   #4
Household Handyman
Rewards Points: 1,408
This sounds as if it is an opener problem: The door is going just slightly passed the "down stop" position within the controller, actually going just a bit past the micro-switch which stops the controller motor. The weight of the door makes it go past this micro-switch, the the controller recognizes that the switch is not made, puts the controller into the "raise door" mode until the switch is satisfied. All that is needed is some fine-tuning on the door's "stop-down" and "stop-up" adjustments. Remember: If you adjust one setting you will more than likely have to adjust the other just a bit.
The Following User Says Thank You to Thurman For This Useful Post:
Windows on Wash (12-30-2012)
garage room bmorekid Building & Construction 4 01-02-2012 01:22 AM
Garage door removal bmorekid Carpentry 2 12-31-2011 11:18 AM
Cover Garage Vents jeremywatco Building & Construction 2 01-31-2011 12:56 AM
Close to building my garage. Need help on framing a roll up door, some other things. J S Machine Building & Construction 0 01-06-2011 07:50 AM
need to fix the foundation on this slab garage cnn7 General DIY Discussions 3 04-20-2010 06:11 PM
