-   Windows and Doors (http://www.diychatroom.com/f104/)
-   -   garage door open and close (http://www.diychatroom.com/f104/garage-door-open-close-167742/)
andrepoitras 12-29-2012 11:51 PM
I've installed a new trolley. Door closes and then rises about a foot then stops.
Missouri Bound 12-30-2012 12:19 AM
More information please.....is this an opener problem or a spring problem?:wallbash:
joecaption 12-30-2012 12:31 AM
What style spring is it?
http://ddmgaragedoors.com/diy-instru...leshooting.php
Thurman 12-30-2012 10:15 AM
This sounds as if it is an opener problem: The door is going just slightly passed the "down stop" position within the controller, actually going just a bit past the micro-switch which stops the controller motor. The weight of the door makes it go past this micro-switch, the the controller recognizes that the switch is not made, puts the controller into the "raise door" mode until the switch is satisfied. All that is needed is some fine-tuning on the door's "stop-down" and "stop-up" adjustments. Remember: If you adjust one setting you will more than likely have to adjust the other just a bit.
