Garage Door Just Hums, Doesn't Open - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 03-19-2011, 12:06 PM   #1
Garage door just hums, doesn't open
I'm trying to troubleshoot my garage door. It started to have problems opening, it would open 1/4 of the way and that was it.. so I greased all the wheels, and the screw drive thing, it did the same thing, I then increased the force that it would open up and it worked fine.
A couple days pass, and now it just hums when I try to open it. If I disengage the door the screw doesn't move either.. the garage door opener just hums for 3 seconds then shuts off. The light still comes on.
Any ideas?
ibjames is offline   Reply With Quote
Old 03-19-2011, 12:11 PM   #2
Experienced
Jackofall1's Avatar
What song is it humming? Yankee doodle?
You have disengage the door, does it go up and down easily?
If the door moves freely when disengaged, I would say there is something jammed inbetween the worm gear and drive gear.
Does it do this going in both directions?
Are you sure you turned the torque setting the correct direction?
Mark
Old 03-19-2011, 12:51 PM   #3
Rewards Points: 558
Some things you should take a look at are:
1) Take a look and see if your torsion spring is broken. If so, you need to replace it.
2) Check to see if your track is bent. If so, try to straighten the track, adjust if possible, if not replace track.
3) You can also check to see if your extension spring is broken. If so, replace the broken spring.
epson is offline   Reply With Quote
Old 03-19-2011, 02:14 PM   #4
Household Handyman
Rewards Points: 1,408
"lbjames": The aforementioned suggestions are correct, but maybe need to be put in order. Do this with the garage door DOWN!
1) Disconnect the garage door opener from the garage door, there should be a small red rope/string hanging from the "sled" which moves towards the opener when opening the door, and away from the opener when closing the door. IF this rope/string is missing you should be able to find the part you can pull to disengage the sled from the actual door hardware. 2) Once this is disconnected try operating the opener to open the garage door. IF the opener tries to move, (you mentioned screw drive so--) watch the screw to see if it rotates, and see if the sled moves toward the opener. IF the sled moves, but stops before reaching close proximity to the opener, the open adjustment may need to be re-set. This will work the same for closing the opener. Once you have the sled somewhat adjusted to the approximate settings, then proceed to the actual door, with the sled still unattached. IF you cannot get the screw to turn or the adjustment settings to work, you may have a more serious problem than a DIY person can do. Call in some help. BUT, IF you can get them set: Try raising the garage door without straining yourself. It should be this easy. IF you can raise and lower the door unit and it seems relatively easy, the door may be just fine. IF there is a problem with raising the door, have someone clamp a pair of Vise-Grips onto the track just a bit lower than where you find the problem. Then investigate the problem, fix this and proceed. Remove the Vise-Grips when done. Re-attach the sled unit to the door and see if this help. You will need to make some fine-tune adjustments when all is attached together.
Old 03-19-2011, 09:34 PM   #5
Rewards Points: 252
Your drive gear inside the opener may be stripped. If you can open the door manually, then look at the gear. On mine, they are nylon and wear out. I find a white powder inside the unit and the gear is gone. I think it costs around $30 to fix it if that's the problem.
Marty1Mc is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 03:30 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 08:20 PM
Garage remodel - adequate foundation? WillK Building & Construction 1 01-21-2011 01:50 PM
Insulate finished garage ceiling or condition garage? pasichnyk Building & Construction 19 12-06-2010 01:46 AM
Garage door hard to open bucksone General DIY Discussions 4 01-02-2010 06:44 PM
