Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Windows and Doors
Old 11-02-2012, 06:51 AM   #1
Garage door issues...PLEASE HELP ME
I am trying to figure out why my garage door liftmaster 1/2 HP is not working. I opened it up and all the wiring looks sound. When I hit the wall button to open the door the light in the back comes on and there is a clicking noise. I did notice that the sensors at the base of the garage door are not functioning. There is no green or red light coming on on the units. Will the sensors not working cause the whole liftmaster to stop working? Or is it something else that I need to look at? Please help!
elucidator59 is offline   Reply With Quote
Old 11-02-2012, 07:24 AM   #2
Super Moderator
Yep---those sensors need to work or nothing happens---
elucidator59 (11-04-2012)
Old 11-02-2012, 11:24 AM   #3
Did you reliece the door from the track by pulling on the rope and try lifting it to see if it's easy to open.
Should be able to lift it with one hand if it's adjusted right.
Did you look at the plastic gear to see if it's stripped?
Old 11-04-2012, 04:19 AM   #4
Yes, It is disengaged currently and that's how I've been getting in and out. The gears look good, no stripping and well lubed. All the wires are connected and look intact, no rust! Any Ideas????
Old 11-04-2012, 05:16 AM   #5
JOATMON
ddawg16's Avatar
There are LED's on the eyes that let you know the beam is not blocked. If the photo eyes go out of alignment...LED's not on.
Make sure the eyes are aimed at each other.
Common Sense is like Deodorant. Those that need it the most don't use it.
My
and
ddawg16 is online now   Reply With Quote
Old 11-04-2012, 06:52 AM   #6
My husband told me that he disconnected the sensors after the garage door stopped working because they were not alligned properly. So I guess that answers one question.... My next step I guess is to reconnect them and see if it makes anything work.
Old 11-12-2012, 04:02 PM   #7
Yep. Those sensors have to be functional before that door will work. Actually I think if the door is in the down position it should go up but it definitely won't go down.
crawdad62 is offline   Reply With Quote
Garage Roof Support & 2nd Floor Addition Info? olimits7 Building & Construction 3 10-15-2012 07:42 PM
Junction box feeding power to garage from house gmbojanowski23 Electrical 4 10-02-2012 11:20 AM
Expanding Garage INTO house (goodbye Den) texaopian Building & Construction 16 11-07-2011 11:32 PM
Detached garage subpanel options? jeffiebean Electrical 6 03-15-2011 09:20 PM
