Garage Door Handle And Lock - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 05-24-2011, 11:24 AM   #1
GGA
Garage door handle and lock
The T handle on the garage door is quite old and the key won't open the lock. There is no other access into the garage. How can I open the door without damaging it?
GGA is offline   Reply With Quote
Old 05-24-2011, 11:42 AM   #2
Rewards Points: 152
The first thing that I would try is some Lock Ease, which you should be able to get at your local hardware, auto parts store, or big box. Carefully work it in and out of the lock with the key.
Old 05-24-2011, 01:49 PM   #3
Rewards Points: 5,336
If lubrication doesn't work, try PB Blaster or liquid wrench. Let it set for a few hours before you try to turn the key.
If all else fails, pick up a new lock and cut this one off.
All exterior locks should be lubricated at least twice a year.
Ron
Old 05-24-2011, 02:36 PM   #4
fabrk8r
fabrk8r's Avatar
Do you have access to the garage through a walk-through door? If so you may be able to lubricate and free the lock easier from the back side.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
garage plan HoweD Building & Construction 7 03-28-2011 08:14 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
How To Replace an Old Garage door Lock system apetrag How To Guides 4 12-17-2009 06:31 PM
Broken Lock/Manual Garage Door/Help! Sheila4467 General DIY Discussions 7 11-07-2009 02:43 AM
garage door lock jack_j General DIY Discussions 1 12-27-2006 06:40 PM
