Which Garage Door? - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 04-18-2012, 01:58 PM   #1
Rewards Points: 12
Which Garage Door?
Hi
I need to install an inexpensive insulated 8x7 garage door. Two of the big box stores have one for the same price, but different brands. From what I can see, the specs seem similar. One is made by Clopay and the other ReliaBilt.
Does anyone have an experience with the pros-and-cons of each?
Thanks . . . Brian
JagGuy is offline   Reply With Quote
Old 04-18-2012, 03:15 PM   #2
In a little over my head
Rewards Points: 706
I have a Clopay with a Genie opener installed. It has opened and closed several times a day for about 15 years with no problems or complaints. Mine is uninsulated; I might do that differently if I did it again.
ratherbefishing is offline   Reply With Quote
Old 04-18-2012, 03:37 PM   #3
Rewards Points: 12
A good recommendation
Thanks for the Clopay info. There are no user reviews for the Clopay door, which I find a little strange. The other door has mixed reviews, the negative mainly to do with missing parts. I've had Clopay before too, when they were wood. You've given yours a workout and it's held up. That's good to know.
Old 04-18-2012, 06:10 PM   #4
I would go for the Clopay. Lowes "Reliabilt" changes manufacturers every few years. I believe it is Ankmar right now. Hard to get replacement parts down the road for a door that may have changed.
pkrapp74 is offline   Reply With Quote
Old 04-18-2012, 06:20 PM   #5
Registered User
Rewards Points: 5,516
I have 2 Clopays, a 9x7 w.springs and a 9x8 w. torsion. Installed 12 years ago, no problems yet. both used eveyday, smaller twice a day. Had to adjust the closing distance 3 times over that time period. Insulated, no leaks, fairly quiet (depends on the openers). Have Chamberland (Costco) openers now, way better than Sears.
Gary
Old 04-18-2012, 06:48 PM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,744
We used Clopay with success in my business.
Can't speak to the ReliaBilts but I have Clopays in my home as well.
Very well built.
Old 04-20-2012, 11:36 AM   #7
Rewards Points: 12
Thanks everyone for taking the time to help me.
I appreciate it.
Brian
Garage Insulation yamster Insulation 0 07-01-2011 01:30 PM
How to find a garage door dealer meburdick Building & Construction 5 06-28-2011 08:29 PM
Garage Door Assistance dukes32 General DIY Discussions 2 06-15-2011 12:11 PM
Garage Door Install Opinions detailedEye Building & Construction 4 03-31-2010 10:15 PM
Old Genie Garage Door Opener cmgith General DIY Discussions 3 11-27-2006 08:53 PM
