Gap In Door For Weatherstripping. - Windows and Doors - DIY Chatroom Home Improvement Forum
Old 02-03-2014, 11:44 AM   #1
Rewards Points: 2,166
Gap in door for weatherstripping.
I can't win.
Learned I could pull out old gummy weatherstripping around door. Painted door trim and today tried to put new weatherstripping in but that gap where weatherstripping goes in is filled with paint in many places. Never thought to clean it out or check it when paint was wet.
I'm trying to clear the gap with a Box cutter and it's not easy. Tried a screwdriver and my arms are tired.
Wonder if my Dremel will clear that narrow strip without making it too wide so that weatherstripping falls out.
Startingover is offline   Reply With Quote
Old 02-03-2014, 12:36 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,728
Utility knife is your best bet with a proper and sharp blade on it.
The Following User Says Thank You to Windows on Wash For This Useful Post:
Startingover (02-03-2014)
Old 02-04-2014, 04:40 PM   #3
Painting Contractor
Rewards Points: 155
A 5 n 1 putty knife works well also, using the point to dig out the paint.
VAProPainter is offline   Reply With Quote
The Following 2 Users Say Thank You to VAProPainter For This Useful Post:
Startingover (02-05-2014), Windows on Wash (02-05-2014)
Old 02-04-2014, 07:01 PM   #4
DIY staff
Rewards Points: 7,174
If you are careful --a multi-tool would make fast work cleaning out the groove.
The Following 2 Users Say Thank You to oh'mike For This Useful Post:
Old 02-05-2014, 04:38 PM   #5
Ok, I have a putty knife like that. I'm having trouble on the side near the hinges and will have to wait for a dry day and take the door off.
Then, the old weatherstripping had a flatter edge which slipped into the frame groove. The new weatherstripping has a thicker edge and I can't get it in the grove. The flat edge is ribbed and it's just not going in.
I think I'll look online for some similar to the old style. HD had it a few months ago but now they don't carry it.
Old 02-05-2014, 06:03 PM   #6
DIY staff
In this area ACE hardware is the place I find the best variety of weather strips----
Startingover (02-06-2014)
Old 02-06-2014, 07:08 AM   #7
Thanks mike,
One last question for now. In post # 3, the photo of the putty knife..........why is one side cut out in a circle shape?
Old 02-06-2014, 07:13 AM   #8
Gymschu's Avatar
Rewards Points: 842
Originally Posted by Startingover View Post
Thanks mike,
SO, it is used to remove excess paint from roller covers.
The Following User Says Thank You to Gymschu For This Useful Post:
Old 02-06-2014, 12:27 PM   #9
Wow, I did not know that. I've been using my fingers and my entire hand gets covered in paint and it runs down my arm.
Old 02-12-2014, 05:32 PM   #10
DIY staff
A painters tool is mighty handy to have around the house---
Old 02-13-2014, 07:16 PM   #11
Registered User
Rewards Points: 5,516
If you find the multi-tool blade or the utility knife tend to cut the wood, try the squared end of a metal strap or metal joist hanger- they are different thicknesses. Drag it down the groove/dado to clean, it has less tendency to cut wood where you don't want/need.
Gary
